Like Tree4Likes
Old 01-31-2011, 06:13 PM   #1906
smokinu's Avatar
Trader Rating: 60 (98%+)
[QUOTE=hyperdesigns;8579255]
Originally Posted by smokinu View Post
heres pics of robs car after i did a little rewire to make it all nice and smooth.. going to re do the diffs tonight as well get it all nice and clean again!
marcus its charlie from facebook. nice looking tt. just got mine a week ago. still have not heard anything from viper yet... hopefully soon. what diff oils you go with? i went 5,5,1 same as my hyper 10sc. works well
going to put 5/5/2 in it.
its not my hyper though. i am just a pit guy for a local who works long random hours.. so i help him by working on his gear getting it dialed..
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 01-31-2011, 08:31 PM   #1907
Trader Rating: 82 (100%+)
yes you do next project is on the way todat t 4.1 we are going to be putting the tekin in it and as always thanks for the help
RsDrake77 is offline   Reply With Quote
Old 01-31-2011, 08:52 PM   #1908
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Slash65 View Post
By upper shock mounts are you referring to bushings?
Yep. Gotta mount'em some how.
heavyjeffd is offline   Reply With Quote
Old 01-31-2011, 08:55 PM   #1909
Noob question:
What effect would replacing the rear dogbones with CVA's have on the car? Does it change the handling much?
I'm tired of searching the track for my lost dogbones.
socialsumo is offline   Reply With Quote
Old 01-31-2011, 08:59 PM   #1910
thecman26's Avatar
Trader Rating: 98 (100%+)
Originally Posted by socialsumo View Post
Noob question:
It shouldn't change much at all, you just won't have to chase bones any more!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 02-01-2011, 12:50 AM   #1911
redthunder's Avatar
hi all, bit of a noob question here, I've run about 6 packs through my tt, first time at off road and its a blast, my tt has a 550 novak ballistic motor 4.5 turn, with a 15t pinion, and its getting rather hot, as in cant touch it hot... so is this normal or do I need to go down some teeth? btw its got a xerun 120a esc if that makes any difference, but that stays at room temp no matter what.
redthunder is offline   Reply With Quote
Old 02-01-2011, 01:55 AM   #1912
smokinu's Avatar
i would drop down to a 14t pinion..
the truck i posted just last page has a 12t with a 4.5t novak and it never even got over 80F.
Marcus P.
Old 02-01-2011, 02:01 AM   #1913
redthunder's Avatar
awesome, cheers for the quick answer, ill go with the 12 then, see how it goes and may go to 13t,
Old 02-01-2011, 02:47 AM   #1914
antonio_cadiz's Avatar
hello!
Why would you use this?
http://www.amainhobbies.com/product_...mm-Shim-Set-10
Where do you put?
I need stiffer springs which model to buy
sorry for my english
my car
thanks
antonio_cadiz is offline   Reply With Quote
Old 02-01-2011, 04:47 AM   #1915
A Novak 4.5T 550 on 2s with a 20T pinion should pull wheelies?
Hyper Mini STe (with custom chassis - 10TT) Novak 4.5T 550 motor/150A ESC
Phoenix ST
www.youtube.com/TheAL3xGR
AL3xGR is offline   Reply With Quote
Old 02-01-2011, 05:26 AM   #1916
Trader Rating: 36 (100%+)
[QUOTE=antonio_cadiz;8581246]hello!
Why would you use this? In some cases, the crown gear to diff pinion is tight. You use these shims to move the crown away to loosen it up.
Where do you put?
I put one on the outdrive on the side opposite the crown gear to push it away from the pinion.
A lot of racers I know are using these...
http://www.amainhobbies.com/product_...t-Blue-406-N-M
You have to be careful though. When you open the package, you'll find two different sizes. The shorter set is used in the front. It is also suggested to cut 1 1.2 coils off of the front springs to use on the Hyper TT.
Hope all this info helps
NitroOB4You is offline   Reply With Quote
Old 02-01-2011, 05:34 AM   #1917
hello
very thanks. NitroOB4You
Old 02-01-2011, 06:15 AM   #1918
I bought these shims too.Any opinion about my question?
Phoenix ST
Old 02-01-2011, 06:33 AM   #1919
Toiffel's Avatar
Trader Rating: 52 (100%+)
Originally Posted by DirtyCookieX View Post
Greatly appreciate all the input guys! I guess Ill stick with the SCT combo and gear up to maybe a 16T. One more question I swear, is it totally ridiculous to run a 1-5-1 diff set up? (I really liked the stock set up with the silicone grease, so I wanted a similar balanced set up)
I think your spot on, that was exactly what I was thinking, currently running 3-5-2 good but not great, going to try 1-5-1 and hoping that's going to be the ticket!!
Esteban "BBQ" Baquero
Barry "Barely" Goodwin's worst nightmare.....
Toiffel is offline   Reply With Quote
Old 02-01-2011, 06:49 AM   #1920
G_WORD's Avatar
Trader Rating: 112 (100%+)
in case you forgot i tried 1-5-1 already and you saw it first hand. gonna try 3-5-3
Crispy Critters Hobby Shop & Raceway
Mugen MBX7R / AE B6D / TLR 22-4 2.0
G_WORD is offline   Reply With Quote
