Like Tree4Likes
Old 01-30-2011, 08:01 PM   #1891
hogmansp's Avatar
Trader Rating: 47 (100%+)
Originally Posted by hyperdesigns View Post
i have the 3800kv 4 pole castle sct system in my tt. its just stupid fast but very fun to drive. i would not want anymore motor than that. another guy had a 4.5 in his and they were about the same. i was pulling wheelies on the str8way with the stock tires
Had my epa turned down from 120 to 60 and the 4.5 was still to much for the track. I would say the 540 can 8.5 rs pro is plenty for indoor racing.
hogmansp is offline   Reply With Quote
Old 01-30-2011, 08:22 PM   #1892
Arigato's Avatar
Originally Posted by DirtyCookieX View Post
I need input on a new motor/esc set up. Currently I have the CC SCT combo which is a beast in the sc10 but it's just "enough" in this rig. I think I want to stay with castle creations and try out the MMP but im clueless as far as Castle's motor choices. I think I want something comparable to a 4.5T, so which KV rating would be similar to this?
I've run my CC 4600kv 1406 motor with the mmpro esc for two visits to two different tracks now and totally dig it. It's very fast and surprisingly smooth. 4 pole motors are awesome.
Dog House Racing
XRay XB8E
XRay XB4
XRay XB2
XRay T4'17
Arigato is offline   Reply With Quote
Old 01-30-2011, 08:24 PM   #1893
Originally Posted by utah300rum View Post
wow......you must run on a large track.
I am thinking of trying to tone down my Castle SCT....I can lift the front up at will if I got the traction. I'm thinking this will be too much for my track, its tight and technical no straight aways.
which pinion are you running?
HB Ve8 HHH
DirtyCookieX is offline   Reply With Quote
Old 01-30-2011, 08:30 PM   #1894
hyperdesigns's Avatar
i am running a 16t on mine.
really hoping the class takes off. been letting everyone drive it and everyone has loved it. but i have my doubts now. thats ok it will make me a better 4wd sc driver after practicing with the tt.
hyperdesigns is offline   Reply With Quote
Old 01-30-2011, 09:40 PM   #1895
utah300rum's Avatar
Trader Rating: 27 (100%+)
still have the stock 13t......I was thinking of going to the 11t, but I want to wait till I get some more run time and temps.
Spooky's Racing for Asphalt & Carpet, Blacksheep Raceway for off-road, Utah Mountains for bashing!
utah300rum is offline   Reply With Quote
Old 01-30-2011, 09:49 PM   #1896
thecman26's Avatar
Trader Rating: 99 (100%+)
I've been running mine at the track the last 2 chances and its a blast!
I just have an old losi xcelorin speedo and novak HV 6.5 in it and its crazy fast with a 16t pinion, and it comes off at 85*... Unfortunately 16 is the biggest pinion I have
Will be getting a 17 and 18 soon! Now if I could just calm down the steering and I'd be golden!
These are awesome little truggies!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 01-31-2011, 04:50 AM   #1897
I changed from 26T to 20T because of the cogging on 3s...(bad esc - or badly overgeared motor....) (novak 4.5T 550 with sensored esc)
Hyper Mini STe (with custom chassis - 10TT) Novak 4.5T 550 motor/150A ESC
Phoenix ST
www.youtube.com/TheAL3xGR
AL3xGR is offline   Reply With Quote
Old 01-31-2011, 08:27 AM   #1898
Trader Rating: 42 (100%+)
My RS PRO and 8.5 with the stock pinion (13) was very nice to drive. I have the boost @ 30. I could easily go upon boost and add turbo "IF" I needed more power.
I have 3-7-1 in the diff's. 35F 30 R in the shocks. I stood the rear shocks up by going out on the rear tower and in on the rear arm. No steering mods and had all the steering I could ever want with the stock orange springs. I tried the blue springs on the front and it was twitchy on the steering ( probably good for a real tight small track). Looking forward to running it more soon. I also moved the rear lower shock to the middle hole on the arm and let my friend drive that and it looked good with great slow steering and a very driveable push on the higher speed corners.
Mike
miket3 is offline   Reply With Quote
Old 01-31-2011, 11:39 AM   #1899
Greatly appreciate all the input guys! I guess Ill stick with the SCT combo and gear up to maybe a 16T. One more question I swear, is it totally ridiculous to run a 1-5-1 diff set up? (I really liked the stock set up with the silicone grease, so I wanted a similar balanced set up)
HB Ve8 HHH
Old 01-31-2011, 11:44 AM   #1900
You can use whatever you want,depending on the track you are running and your driving style.You can also use lithium grease(I was using it in the beginning and then I changed to silicone oils) as the 1000wt oil.
Phoenix ST
Old 01-31-2011, 02:57 PM   #1901
1Fastpede's Avatar
Trader Rating: 46 (100%+)
Anyone know of any possible shock options?
1Fastpede is offline   Reply With Quote
Old 01-31-2011, 04:00 PM   #1902
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
The Associated T4.1 shocks bolt right on. Just make sure you get the upper shock mounts too since the Ofna ones snap on.
heavyjeffd is offline   Reply With Quote
Old 01-31-2011, 04:57 PM   #1903
Slash65's Avatar
By upper shock mounts are you referring to bushings?
HoBao Hyper 10 TT
Sanwa MX-V
HobbyWing XeRun V2.1
Dynamite 6.5T
Slash65 is offline   Reply With Quote
Old 01-31-2011, 05:00 PM   #1904
smokinu's Avatar
Trader Rating: 60 (98%+)
heres pics of robs car after i did a little rewire to make it all nice and smooth.. going to re do the diffs tonight as well get it all nice and clean again!
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 01-31-2011, 05:54 PM   #1905
[QUOTE=smokinu;8578921]heres pics of robs car after i did a little rewire to make it all nice and smooth.. going to re do the diffs tonight as well get it all nice and clean again!
marcus its charlie from facebook. nice looking tt. just got mine a week ago. still have not heard anything from viper yet... hopefully soon. what diff oils you go with? i went 5,5,1 same as my hyper 10sc. works well
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
