Like Tree4Likes
Old 01-28-2011, 11:38 PM   #1861
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
Finally ran the 10TT good tonight, put about 6 packs through it.
Fun to drive, pretty responsive, the RSPro/6.5/12t pinion combo is great, tons of bottom end, wheelying all over the place.
The only thing I'm needing is more low speed steering. Anyone accomplish this? If so, how.
heavyjeffd is offline   Reply With Quote
Old 01-29-2011, 12:24 AM   #1862
Trader Rating: 82 (100%+)
What servo u running I'm using a savox and had to give it some expo cause it was turning way 2 fast
RsDrake77 is offline   Reply With Quote
Old 01-29-2011, 12:31 AM   #1863
heavyjeffd's Avatar
KO Propo 2368.
It's not the speed, it turns plenty fast, it's just on really tight hairpin corners, there almost doesn't seem to be enough lock, I go wide.
Old 01-29-2011, 05:01 AM   #1864
Front
0 degrees camber
2.5 degree toe out
3000wt diff oil
u will turn on a dime trust me
Hyper 10SC
Team Terribles, Mike's Hobby Shop Carrolton Tx.
Up and coming factory team driver
slowslug is offline   Reply With Quote
Old 01-29-2011, 06:39 AM   #1865
TeamJammin!'s Avatar
Originally Posted by JayRC66 View Post
I am currently making my own inserts out of 1/8 truggy inserts. Left them over night to dry. This sunday I will test them out.
There are 4 of us, 5 including you, that have been racing the TT now at LIR. Hopefully more will show up!
TeamJammin! is offline   Reply With Quote
Old 01-29-2011, 07:25 AM   #1866
heavyjeffd's Avatar
Originally Posted by slowslug View Post
Front
0 degrees camber
2.5 degree toe out
3000wt diff oil
2.5 degrees toe out? Jesus, lol.
I need to get some 3k, all I had was 5k when I rebuilt them. Probably pick some up today.
Old 01-29-2011, 07:43 AM   #1867
hogmansp's Avatar
Trader Rating: 47 (100%+)
I am going to try 2-7-1 today. -1 degree camber and 1 degree toeout. How do you have your front arms positioned? Today I have lower arm all the way back and upper arm all the way forward. Less caster should = easy turn in and smooth exit. Going to start with the front and rear sway's also.
hogmansp is offline   Reply With Quote
Old 01-29-2011, 07:45 AM   #1868
heavyjeffd's Avatar
I have the arms like that already.
3-7-1 is what I wanted to run but all I had was 5-7-2, gonna pick up some 3k and 1k today.
Old 01-29-2011, 09:43 AM   #1869
JayRC66's Avatar
I will be there tomorrow with the truck. I just got the Proline Closed Cell Inserts for the truck. See you guys then!
Jovanny S.
Losi, Serpent, Schumacher, Ofna.... yea I got a little bit everything.
JayRC66 is offline   Reply With Quote
Old 01-29-2011, 10:04 AM   #1870
JayRC66's Avatar
Originally Posted by Dragula426 View Post
I run that exact same set-up in my lightened and modded Hyper 10, and its not laking any power! In my Ren & Stimpy Voice, "You Sick Little puppy you"!
I have those blue springs. How are they working for you? will try them tomorrow.
Jovanny S.
Old 01-29-2011, 10:54 AM   #1871
tedstryker's Avatar
Trader Rating: 75 (100%+)
KO Propo 2368.
Remove the front sway bar makes a huge difference ...when in tight turns...
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
tedstryker is offline   Reply With Quote
Old 01-29-2011, 11:14 AM   #1872
pword's Avatar
Trader Rating: 26 (100%+)
+1. removed sway bar last night and yes, big difference!
tedstryker, where do you race your TT?
Critters | 46RC | Trains and Lanes | BarnstormersRC
pword is offline   Reply With Quote
Old 01-29-2011, 06:24 PM   #1873
anybody run 1-5-5 at ocrc?
HB Ve8 HHH
DirtyCookieX is offline   Reply With Quote
Old 01-29-2011, 08:19 PM   #1874
G_WORD's Avatar
Trader Rating: 112 (100%+)
he's a backyard basher
Crispy Critters Hobby Shop & Raceway
Mugen MBX7R / AE B6D / TLR 22-4 2.0
G_WORD is offline   Reply With Quote
Old 01-29-2011, 08:27 PM   #1875
smokinu's Avatar
Trader Rating: 60 (98%+)
raced Rsdrake77 hyper 10tt today!
with the 4x4 sc class it held its own tqed and won! truck was on rails with a havoc3s and 4.5 combo!
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
