Like Tree4Likes
Old 01-28-2011, 06:03 AM   #1846
Trader Rating: 42 (100%+)
Originally Posted by jrz93 View Post
Or you could get the hpi ones for $5
would you happen to have a part # ?
thanks
miket3 is offline   Reply With Quote
Old 01-28-2011, 06:55 AM   #1847
Trader Rating: 82 (100%+)
got mine to the track today crazy fast geared it down to a 12 on pinion with novak 4.5 hv 550 can first turn hit the pipe and upper lower arms pulled through the hub went right back in though only problem i see is no free roll off throttle u let go and it wants to stop anyone else have this problem
RsDrake77 is offline   Reply With Quote
Old 01-28-2011, 08:28 AM   #1848
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
Sounds like your gear mesh is too tight, mine freewheels fine.
heavyjeffd is offline   Reply With Quote
Old 01-28-2011, 08:40 AM   #1849
Will check it thanks
Old 01-28-2011, 09:10 AM   #1850
aegiswa's Avatar
Trader Rating: 14 (100%+)
Make sure your ESC has the drag break is backed off - I have mine set to 0 to get it like I want it.
Not sure what your used to driving but it is way different then any 2WD -
Gear mesh you need a good amount of backlash there - set it up similar to a nitro in terms of clutch bell to spur backlash is what I find.
AegisWA <><
Ofna Hyper SC10 + 2S Kinetic/Ballistic 5.5 (550)
Ofna Hyper 10TT + 2S Kinetic/Ballistic 6.5 (540)
Team Associated - FT SC10 + 2S Kinetic/Ballistic 10.5
Mugen - MBX6 + Nova - hibernating 'till things warm up and dry-out....
aegiswa is offline   Reply With Quote
Old 01-28-2011, 09:16 AM   #1851
Thanks will check novak and see I think it was off though mes is set with alittle play between gears so should it b more I started with 2 hyper 10 sc so a little use to them but this thing nose dives hard if you dont stay in throttle
Old 01-28-2011, 09:23 AM   #1852
Arigato's Avatar
I'll post a more inclusive review tonight or tomorrow, but I installed the new Castle 4600kv 4 pole motor in mine last night. It's tiny but NASTY. I ran it for about 5min. in the street hard on the throttle and brakes and it only got up to 95 degrees. Speedwise it felt almost as fast on 2s as my 3600kv Neu motor does on 3s.
Dog House Racing
XRay XB8E
XRay XB4
XRay XB2
XRay T4'17
Arigato is offline   Reply With Quote
Old 01-28-2011, 09:24 AM   #1853
aegiswa's Avatar
Yeah - I found that as well, that's why I turned the drag brake to 0 it helped some... I still stay on the throttle a touch to keep the nose up but just not as much.
I also reduce the minimum break to about the lowest setting as well -
I know with the Kinetic ESC and NovaLink I can unlink the two otherwise they seem to affect each other (drag break and minimum break).
AegisWA <><
Old 01-28-2011, 06:16 PM   #1854
I was excited to pick up my tt today and race it tomorrow but it came with a broken front arm in the box. they screwed the lower pillow ball in too far and cracked the arm
davo798 is offline   Reply With Quote
Old 01-28-2011, 06:20 PM   #1855
S/X Runner's Avatar
Trader Rating: 37 (100%+)
TT videos
http://www.youtube.com/user/SXRunner...2681FFF86571E5
S/X Runner is offline   Reply With Quote
Old 01-28-2011, 07:09 PM   #1856
hogmansp's Avatar
Trader Rating: 47 (100%+)
New layout on the TT. RX8 Sc4x 4.5 14 42 gearing. Few mods here and there. We will see how it runs out tomorrow!
hogmansp is offline   Reply With Quote
Old 01-28-2011, 08:01 PM   #1857
Dragula426's Avatar
I run that exact same set-up in my lightened and modded Hyper 10, and its not laking any power! In my Ren & Stimpy Voice, "You Sick Little puppy you"!
Team Tekin
Jeffery Racing Concepts
Little 'O' Speedway
Extreme Graffix
Dragula426 is offline   Reply With Quote
Old 01-28-2011, 09:32 PM   #1858
nice and clean looks great
Old 01-28-2011, 09:37 PM   #1859
hogmansp's Avatar
I don't care for the rat nest on top of the rx but can't bring myself to shorten the wires just yet!
Old 01-28-2011, 10:14 PM   #1860
s/xrunner thanks for the videos you still running losi ten conversion i wish i would have bought your hyper tt that thing was off the hook mines coming along though
is there a way to unmount the tires and change the foams or do i have to buy everything new and what tires and foams are good
