Like Tree4Likes
Old 01-25-2011, 05:28 AM   #1816
1Fastpede's Avatar
Trader Rating: 48 (100%+)
Originally Posted by justbeastit View Post
I did have this problem when I first changed out the grease in the center diff for oil. What I did to remedy it was to put a small bead of "Ultra Grey high temp silicone" that I use for water pumps and stuff on the paper gasket of the diff case. I held the spur, put the paper gasket on the spur, put a small amount of the silicone gasket sealant on it, then put it on the diff housing. If you do this, let it sit for a few hours to dry and then you're golden. Haven't leaked a single drop of diff fluid since. Buddy of mine did the exact same thing and he hasn't had any problems either.
i also did the same with perfect results!
1Fastpede is offline   Reply With Quote
Old 01-25-2011, 05:46 AM   #1817
Trader Rating: 36 (100%+)
I recently changed to the STRC gear for no other reason than because it existed. That said, I didn't experience any problems with the stock spur. I did add diff silicone before I ever ran it, and in doing so, I used liberal amounts of...
http://www.roguemotorsportz.com/i643...ng&ad=Products
...to coat the outdrives and rubber, etc and the stock gear has been fine.
As far as how often to change, it's a personal feel thing, IMO. In my 1/8 nitro, I change every other race day on average. I don't think the TT will be nearly as abusive on things as an 1/8 is so I slack a bit more. I've run I think 6 race days on it now, and have only changed fluid out once. Soooo roughly once a month, maybe.
NitroOB4You is offline   Reply With Quote
Old 01-25-2011, 06:16 AM   #1818
Ooh Yah Shoo Goo FTW
Hyper 10SC
Team Terribles, Mike's Hobby Shop Carrolton Tx.
Up and coming factory team driver
slowslug is offline   Reply With Quote
Old 01-25-2011, 08:34 AM   #1819
1Fastpede's Avatar
Haha, Of course!
Old 01-25-2011, 09:19 AM   #1820
Slash65's Avatar
Default First Run
I finally got out to run it for the first time this last weekend...
All I can say is WOW. Because of the weather I couldn't go to the track so I ran it in the driveway and the street. I have burnout marks in the driveway now.
If the weather improves I will try to make it to an actual track this weekend. I have not changed anything yet, want to run in box-stock and then do the mods as I go along.
HoBao Hyper 10 TT
Sanwa MX-V
HobbyWing XeRun V2.1
Dynamite 6.5T
Slash65 is offline   Reply With Quote
Old 01-25-2011, 10:13 PM   #1821
I love this truggy! Brought it to the track for the first time tonight and had a freaking blast. Probably wont ever drive my SC10 again, haha....
Also when guys list your diff oil set ups as 5-5-2 for example, are you starting from front or back?
HB Ve8 HHH
DirtyCookieX is offline   Reply With Quote
Old 01-25-2011, 10:58 PM   #1822
aegiswa's Avatar
Trader Rating: 14 (100%+)
Front to back, example: |> 5k front -> 5k center -> 2k rear
They are alot of fun - I just wish we could get a class going.
Keep hearing about a 4wheel open/mod class locally - but we just don't seem to get them there the same night or doesn't make the docket..
AegisWA <><
Ofna Hyper SC10 + 2S Kinetic/Ballistic 5.5 (550)
Ofna Hyper 10TT + 2S Kinetic/Ballistic 6.5 (540)
Team Associated - FT SC10 + 2S Kinetic/Ballistic 10.5
Mugen - MBX6 + Nova - hibernating 'till things warm up and dry-out....
aegiswa is offline   Reply With Quote
Old 01-26-2011, 05:46 AM   #1823
Trader Rating: 42 (100%+)
Default 8.5
Originally Posted by Cappy View Post
Dont let go of the trigger in the air. Stay in it till ya land and she flys just fine
Cappy,
would you share your gearing and ESC settings ? I'm also planning to run mine with an 540 can 8.5 and Tekin RS Pro.
thanks
Mike
miket3 is offline   Reply With Quote
Old 01-26-2011, 08:07 AM   #1824
Before a couple of days I was running on road.I noticed that I need a front one-way diff.Any diff that fits directly(or with light modifications)? Or a mod to the stock?
Hyper Mini STe (with custom chassis - 10TT) Novak 4.5T 550 motor/150A ESC
Phoenix ST
www.youtube.com/TheAL3xGR
AL3xGR is offline   Reply With Quote
Old 01-26-2011, 01:11 PM   #1825
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
Default Setups:
Here's my current setup:
Diffs: 5-7-2 Losi
Shocks: 35f/30r Losi, stock pistons (options pistons on order, may go down to 1 hole pistons with 27.5f/22.5r for more pack but softer rebound)
Shock mounting points: Rear: Upper middle hole, inside hole on arm. Front: Middle hole, inside hole on arm.
Have not really messed with camber/caster/toe from stock, just made sure it was the same on both sides.
Ride Height: didn't measure it, but just below dog bones level; running it on a smooth clay track with tons of grip, so as low as possible.
Electronics: Tekin RSPro, Tekin Redline 6.5 w/ 12t pinion, profile 3, no boost/neutral width/drag brake, 100% brake (turn it down on the radio). KO Propo RX and 2367 servo.
Tires: Stock (with mashed potato inserts) and Proline Suburbs in clay compound (may try Double Dees and Barcodes too).
heavyjeffd is offline   Reply With Quote
Old 01-26-2011, 01:24 PM   #1826
-R2-'s Avatar
Diffs: 5-7-2 Losi
Yeah our tires are great but those inserts are trash, but like I said tires are now available by them selves as a set of four. 21245 part num.
SOAR SEIKI 998,Truggy, Buggy and Electric
Flashpoint Fuel/Savox/
-R2- PAINTS/PRO-LINE RACING/AIRTRONICS
-R2- is offline   Reply With Quote
Old 01-26-2011, 01:27 PM   #1827
Cappy's Avatar
Originally Posted by miket3 View Post
Cappy,
thanks
Mike
Roger that Mike !! All i gotta do is make sense of this new software ! LOL
Tekno EB48.3 RX8 Gen2 T8 1900 19T..
Tekno ET48.3 RX8 Gen 3 T8 2000
Tekno |Sweep | Dialed Inc | Boca Bearings | Mels Shells
SLOW THE F%&# DOWN so you can go fast !!!
Cappy is offline   Reply With Quote
Old 01-26-2011, 01:42 PM   #1828
heavyjeffd's Avatar
The tires on the surface we're on are pretty funny. They howl like a 70's car chase. Overall though the clay compound tires from JConcepts and ProLine are killer there.
The only real complaint I had about the truck is the booger colored Vaseline the diffs are filled with. It took me about an hour to get the diffs out and clean all that junk out and fill them with proper diff fluid. Hell I'd rather empty diffs, that stuff was a pain to clean, lol.
Old 01-26-2011, 01:58 PM   #1829
Cappy's Avatar
That it was !!
Well Mike i gotta tell ya that after the update of my ESC and update to my Hotwire soft, it looks like im back to stock settings which really stinks !!!!
Old 01-26-2011, 02:07 PM   #1830
heavyjeffd's Avatar
Depending where you are running, an 8.5 might be a little small. You may end up running a lot of boost and/or timing advance.
