Like Tree9Likes
Old 01-23-2011, 07:57 PM   #1801
pakk's Avatar
Trader Rating: 79 (100%+)
I know the ideal setup is a 550 can, but is anyone getting away with running a 540? What's your setup?
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 01-23-2011, 08:01 PM   #1802
oplaxboy2's Avatar
A guy at the track was running a velenion esc and motor
oplaxboy2 is offline   Reply With Quote
Old 01-23-2011, 08:49 PM   #1803
Dragula426's Avatar
Tekin all the way.... RSpro with a Tekin 6.5 and high torque TT2277 armature. It drags the wing down the front straight! I had to detune it a ton and its still balistic. I have no fear of the 550 motors in a truck this light.
I wish I could get lighter springs though, then I would lighten it all up. For now its a blast, and would love to win one of our races with it. Been 4th and 5th so far. Wrecked the stock foams in just three runs with it....
Team Tekin
Jeffery Racing Concepts
Little 'O' Speedway
Extreme Graffix
Dragula426 is offline   Reply With Quote
Old 01-23-2011, 08:56 PM   #1804
pakk's Avatar
That is what I was hoping for. I happen to have several 6.5s and another RS Pro. Thanks.
*Photon* *SC10 4x4*
RCRD
Old 01-23-2011, 09:35 PM   #1805
Trader Rating: 17 (100%+)
I am getting ready to purchase one of these trucks very soon, but I have a few questions first. I think I have covered this whole thread, but cant find my answers. Thanks a bunch in advance for any help.
I have not been able to find any gear specifications for this truck. Can anyone give me the Spur tooth count, and is it mod1? How about the tooth counts on the differential ring and pinion, or at least the ratio?
How about the stock tires, the pattern looks decent for clay tracks, but do they hook up reasonably well considering they are stock? How about the overall diameter of the tires?
Thanks again for any help.
burnineyes is offline   Reply With Quote
Old 01-23-2011, 09:51 PM   #1806
hogmansp's Avatar
Trader Rating: 47 (100%+)
42t mod 1 delrin spur. Kit comes with a 13t 3mm shaft pinion. Stock tires not bad foams not good. Tires do seem to look like they hook up on a few vid's that have been posted. Bad thing is the come premounted. Tires depend on brand my clay switch 2.0's are 3.92in or 100mm and roll out at 12.65in. Stock tires are 4.125in or 105.5mm and roll out at 13.125. I will get you the ratio tomorrow night if someone doesn't get to it first.
Losi 22 revtech
Kyosho SC-R Big Bores revtech
hogmansp is offline   Reply With Quote
Old 01-24-2011, 03:04 PM   #1807
LDOstrem's Avatar
Default Diffs Diffs Diffs
So this is my first rig with diffs, so the whole diff oil subject is very new to me. When you suggest using something like 5-5-1, what oil rating are you referring to? 5000wt and 1000wt Ofna oil? Or 5000cst and 1000cst AE fluid? Mugen # rating? Or more specifically, what EXACTLY are you using?
Why doesnt anyone makeing desert buggy cage/body's or do I have to fab my own :/
LDOstrem is offline   Reply With Quote
Old 01-24-2011, 03:08 PM   #1808
hogmansp's Avatar
5000wtg ofna silicone diff fluid (or oil). CST ratings are close to removing one zero from the declaired weight (20000=2000) and so on.
Losi 22 revtech
Old 01-24-2011, 03:10 PM   #1809
Anything that ends in "wt" is ok.I use racers edge oils (3-7-3)
Hyper Mini STe (with custom chassis - 10TT) Novak 4.5T 550 motor/150A ESC
Phoenix ST
www.youtube.com/TheAL3xGR
AL3xGR is offline   Reply With Quote
Old 01-24-2011, 03:12 PM   #1810
Lason is offline   Reply With Quote
Old 01-24-2011, 05:11 PM   #1811
-R2-'s Avatar
The tires are now available unmounted, 21247 is the part number. With some Trinity Bomb One inserts will make these tires to have. I Proline foam in mine and I have some good rear bite for those outdoor tracks, on clay I need a harder set of foams.
SOAR SEIKI 998,Truggy, Buggy and Electric
Flashpoint Fuel/Savox/
-R2- PAINTS/PRO-LINE RACING/AIRTRONICS
-R2- is offline   Reply With Quote
Old 01-24-2011, 08:51 PM   #1812
gas-man's Avatar
Trader Rating: 18 (100%+)
I read waay back the stock spur has a leaking/warping problem... are most people upgrading or is the stock working out ok?
thanks
gas-man is offline   Reply With Quote
Old 01-24-2011, 09:11 PM   #1813
Yosh70's Avatar
thanks
What seems to help with the center diff leaking is the delrin gear that ST Racing has.
http://www.amainhobbies.com/product_...nter-Spur-Gear
TLR 8T 1.5, AE SC10, TLR 22SCT
Yosh70 is offline   Reply With Quote
Old 01-24-2011, 10:24 PM   #1814
justbeastit's Avatar
thanks
I did have this problem when I first changed out the grease in the center diff for oil. What I did to remedy it was to put a small bead of "Ultra Grey high temp silicone" that I use for water pumps and stuff on the paper gasket of the diff case. I held the spur, put the paper gasket on the spur, put a small amount of the silicone gasket sealant on it, then put it on the diff housing. If you do this, let it sit for a few hours to dry and then you're golden. Haven't leaked a single drop of diff fluid since. Buddy of mine did the exact same thing and he hasn't had any problems either.
justbeastit is offline   Reply With Quote
Old 01-24-2011, 11:48 PM   #1815
this might be a stupid question but how often do you switch out diff oils?
HB Ve8 HHH
DirtyCookieX is offline   Reply With Quote
