Like Tree9Likes
Old 10-17-2010, 08:18 PM   #166
carcrazy699's Avatar
Trader Rating: 48 (100%+)
Originally Posted by interplanet View Post
I use a 4600 mamba in my 10sc, it gets a little warm, but I think it will be perfect for this truck, I personally think 550 is a bit overkill for this little truck, you really don't need that much torque.
cool so i should probably just stay with the 540 motors and get like a 6.5 then? i havent driven one yet so im not to sure what to get lol
carcrazy699 is offline   Reply With Quote
Old 10-17-2010, 09:18 PM   #167
dspoo2's Avatar
this is what ive been waiting for (wish ae would pull they finger out
i wish that some people would run these here but oh well
David
B44.1 - Novak - Pro-Tek - Spektrum
RC10T4 - Novak - Pro-Tek - Spektrum
soon hyper 10TT
dspoo2 is offline   Reply With Quote
Old 10-17-2010, 09:27 PM   #168
Trader Rating: 9 (91%+)
thats what I am going to run in one, ithink the 550 is way overboard, and you are not getting top end out of the deal.
interplanet is offline   Reply With Quote
Old 10-17-2010, 09:28 PM   #169
nice i guess i will get a 6.5 or a 5.5 then for it. im going to be running a sxx comp esc v1 with it
Old 10-17-2010, 09:31 PM   #170
lbckevin's Avatar
Trader Rating: 91 (99%+)
the 6.5 is a great motor...I am using a 12t pinion.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 10-17-2010, 10:08 PM   #171
awsome i guess i need to get a different pinion for it since all it has is a 13t lol
i see your local in the o.c i will be running this bad boy at ocrc soon once i can get a motor for it. right now all i have is a 13.5 but i know this truggy needs more power
Old 10-17-2010, 10:10 PM   #172
lbckevin's Avatar
Yes...I am local... I work at West Coast Raceway...
Give me a call if you have any questions.
Kevin Smith
Old 10-17-2010, 10:18 PM   #173
awsome! i need to get out there once the track is done and try this little guy out there also.
by anychance you guys have any used motors that will be good for this?
Old 10-18-2010, 02:22 PM   #174
I went with the novak 4.5 550 can motor. Awesome braking and tons of low end power. Getting about 15 minutes to a battery, 2s 20c lipo. Reason i went with that motor is, i also plan to run it in a bigger SC truck here soon.
speedworks is offline   Reply With Quote
Old 10-18-2010, 05:07 PM   #175
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
How do the 6.5 540 motors compare to the 4.5 550 ? Quicker and lighter and warmer? My 4.5 ballistic HV seems a little weak at the top end, I was expecting more.
How are you guys mounting the RX8? The servo plate is too small for it.
BOLISARIO is offline   Reply With Quote
Old 10-18-2010, 05:13 PM   #176
lbckevin's Avatar
Tim Dunn from Nitro House mounted his RX8 on top of the servo, no problem at all.
I had no heat issues at all with the 6.5, 540 motor. I dumped the whole 5200mah pack and the motor was 133 degrees and speedo was 108.
Kevin Smith
Old 10-18-2010, 05:20 PM   #177
BOLISARIO's Avatar
How do the 6.5's stack up against the 4.5 550 performance-wise?
Which 13.0 tekin rotor did you get? There's two versions: TT2273 or TT2277(HT aka high torque?)?
Old 10-18-2010, 05:21 PM   #178
lbckevin's Avatar
I ran the high torque. My speed was fast...Nobody beat me down the straight.
Kevin Smith
Old 10-18-2010, 05:22 PM   #179
BOLISARIO's Avatar
Thanks!
One more question: Are you using the 5mm to 3mm adapter from OFNA or the 3mm mod 1's?
Old 10-18-2010, 05:23 PM   #180
lbckevin's Avatar
Thanks!
I use the OFNA mod 1, 3mm pinions...
Kevin Smith
