Hyper TT 4wd 1/10th Truggy Thread
#1741
#1742
Also what are the sizes of a 540 and 550 motor? Most of the motors I look at dont state 540 or 550. Thanks for the info guys!
#1743
OK but can the RX8 handle 540 sized motors ok without any loss in performance compared to the RS Pro? I only ask because I plan to get into 1/8th scale as soon as I can and plan to run RX8's so I would rather stick with one kind of ESC if I can.
people with a rx8 at my track run it with either a 550 novak ballistic or 550tekin sc motor....regardless of what motor u get u will have to get another motor for an 1/8th scale.
i use a novak gtb and either a 550 or 540 motor the 550 runs A LOT!!! cooler idk what anyone says..550has more rpm tho so it's a choice/depends on what track u run issue.
the only negative issue is that the rx8 is real big for the tt..will not fit under the body unless you move the battery tray fwd and mount it behind the battery.
#1744
DC- IMO, it is a very durable servo, and torque wise should be ok, but at .20, is very slow, especially if you're an experienced racer. If you're just bashing around it will serve you well or if you are used to "RTR" servos, I would say it would be comparable to those in speed.
how about this one?
http://www.savoxusa.com/Savox_SC1258...avsc1258tg.htm
#1745
That is what I am currently using. After two race days, I'm very happy with it. It is noisy, but that's about the only drawback I've noted.
#1746
#1749
Which Pro-Lines are direct bolt ons?
#1750
#1755
