Like Tree4Likes
Old 01-09-2011, 01:41 PM   #1561
Trader Rating: 36 (100%+)
Originally Posted by thecman26 View Post
They are actually for the Jammin SCRT-10 but they work on the lil guy....
http://www.amainhobbies.com/product_...ring-Bellcrank
This will work on the TT? May hafta look into this
NitroOB4You is offline   Reply With Quote
Old 01-09-2011, 03:21 PM   #1562
justbeastit's Avatar
Yes it will work, I have it on my Hyper 10SC which is the same steering parts as the TT. You just have to use the Hyper upper portion of the servo saver unit that connects to the steering servo. I also put the bearings in place of the bushings and it is silky smooth and bullet proof.
justbeastit is offline   Reply With Quote
Old 01-09-2011, 03:23 PM   #1563
prettyboy's Avatar
Trader Rating: 59 (100%+)
What shims are you guys using to shim the diff ? Size or part numbers please..
(ORIGINAL) HIGH POWERED HOBBIES RACE TEAM MEMBER
prettyboy is offline   Reply With Quote
Old 01-09-2011, 03:44 PM   #1564
Dragula426's Avatar
What other bodies fit these TT's? Anyone got pics of somthing else mounted on it?
Team Tekin
Jeffery Racing Concepts
Little 'O' Speedway
Extreme Graffix
Dragula426 is offline   Reply With Quote
Old 01-09-2011, 04:14 PM   #1565
http://redirectingat.com/?id=42X1295...ruggy-103.html
Old 01-09-2011, 05:34 PM   #1566
Anyone know of an upgrade for the front steering knuckles?
Are there any aluminum ones out there or pending?
socialsumo is offline   Reply With Quote
Old 01-09-2011, 07:03 PM   #1567
prettyboy's Avatar
Thanks for the info..
Old 01-10-2011, 11:35 AM   #1568
TeamJammin!'s Avatar
Yeah, I have been asking the same thing. The steering knuckles are crap. Spoke to ofna, they are working on something. IN the meantime, anyone else know of any other steering knuckle setup that will work, thats more durable?
TeamJammin! is offline   Reply With Quote
Old 01-10-2011, 12:20 PM   #1569
Knucles are the plastic parts that are on the pivot balls,right?
I wish there was a C-Hub conversion for this truck....(Do anyone knows if there is one?If anyone knows even for Mini STe...they are the same)
Hyper Mini STe (with custom chassis - 10TT) Novak 4.5T 550 motor/150A ESC
Phoenix ST
www.youtube.com/TheAL3xGR
AL3xGR is offline   Reply With Quote
Old 01-10-2011, 12:54 PM   #1570
MitchellY's Avatar
Trader Rating: 101 (100%+)
Originally Posted by paysonsrt View Post
I have a 10TT on the way, should be here Monday. I also got a MMP and Novac 4.5 from a guy on here to run in it. I read about 30 pages of this thread, but my eyes are getting tired, so I'm sorry if this has already been covered.
What gearing should I start with?
Is the 4.5 too much? Should I go with a 6.5 or something like that?
2s?
3s?
Let me know what you all think would be best. I also have a MMM with a 2200 motor I could always slap that thing in there. I like speed, but must also have torque for the triples with a short run at it.
I run mine with an 18T with a Novak 4.5T Ballisitic 550 motor. Plenty of torque, and speed!
MitchellY is offline   Reply With Quote
Old 01-10-2011, 12:54 PM   #1571
I just recieved my replacement front knuckles, along with a spare set. Going to boil them to see if it helps at all.
I have not seen any replies from anyone stating that another vehicle's will work, so assuming there is nothing out there.
Old 01-10-2011, 01:40 PM   #1572
Anyone know the exact dimension for the width of the front lower arms on the Jammin scrt10? wondering of they will fit the TT. Looking for the width of the lower arm wear the hinge pin goes through. The outside width for part number 40836
Old 01-10-2011, 07:11 PM   #1573
Dragula426's Avatar
Even with the 54mm akerman bar, you still don't get as much steering as the mod I have posted for the Hyper 10 because the longer bar actually hits the posts, you need a V-bend in it to get the full steering radius out of it....Trust me, if my TT ends up running as good as my Hyper 10 with this mod, there's no catching it on a tight track...
Team Tekin
Little 'O' Speedway
Extreme Graffix
Old 01-10-2011, 07:19 PM   #1574
Mod???
Old 01-10-2011, 07:49 PM   #1575
Just wanted to clarify, were you stating that the scrt10 lower and upper arms will fit on the 10tt? if so, I'll order them along with the cnc upgrades and trash the 10tt pivot ball crap..
