2 2s=1 4s ?
Just make a y conector. pos on oneconector and neg on another conector then a wire between the conectors.
This will work you just need to change the connecters to fit your choosing.
http://www.google.com/products/catal...CCkQ8wIwBDgA#p
Or make your own with the same layout.
and waht about the balencer wires?
No on the both blacks to the esc. Take a look at this:
http://scriptasylum.com/rc_speed/_pi...wiring_2.gif~0
if you have to ask, there is a 99% chance that you shouldn't try until you have more experience with lipos.
I use a Thunder Power 1010C and a TP210 balancer with an adapter. I plug both balance plugs into the adapter using the 4S port on the balancer. The adapter does the "thinking" and tells the balancer that it's 4S. Then, use the Y-harness and plug the pair into the charger as 4S.
Paired packs should be balanced and charged together (same exact packs). You'll kill the weaker pack in a hurry if you don't.
Yoiu can buy a serial harness for charging a pr of 2S in series -
http://www.greathobbies.com/producti...od_id=TGHX1000
In series there is a potential to short the lipos thru the connected balance wires. You have to know what you're doing. Its easier and safer to charge them in parallel. Get a Paraboard for the type of balance connector you have and just plug in, setup and charge.
http://epbuddy.com/index.php?main_pa...products_id=84
I charge multiple lipos in parallel.
if so then ill be buying that
Charging in parallel, they have to have the same cell count, they can be diff capacities (no extremes like a 2S 8000mah and a 2S 800mah). I charge two and three 2S lipos at once, all 5000mah.
The lipos need to be close to each other in voltage before you hook them up since they equalize thru the board when connected.
I think its great since I have 3 diff RCs that use two lipos at the same time. No more charging one after another and the waiting.
I use some venom 40c 5000mah, charge and balance seperatly, the batteries are not expensive and venom has a decent warranty. Never a issue on performance, plus if one cell goes bad your not going to be buying a 200.00 4s it will just be a 70.00 2s that most LHS carry.
Just my opinion,
