HELP: Mod 4wd, tekin rs pro, SP 7.5R... it's stock slow..
Hi,
I think something wrong with my setup. I am running a cat sx2 with a tekin rs pro and speed passion 7.5R. I have my tekin set in dual mode with 80% timing (i believe that may add 20* or so). But running cat outside, it doesn't seem fast. It looks slower that my stock 17.5 cougar sv (that with boost of course). My setup doesn't look competitive at all. I have check all of the norms like sensor is connected correctly, a->a, b->b, c->c from esc to motor. Lipo is good (its brand new charged at 35%, i know i need to charge but i doubt this is it). my batter is an elite 5000mah 50c 2s. Im not sure what other details i need to provide... Oh, i am running like a 83T spur and 20T pinion.
Any help would be appreciated!
thx
thx
Hi,
thx
thx
Although 7.5 is a mod, I'd be either be running max timing in the esc in dual or run in sensored only and gradually increacse timing until you get the speed you want with out overheating.
the reason why many peeps run low turn motors (ie 5.5, 4.5T) motors in dual is because they have enough grunt and running a little bit cooler is preferable.
thing is, it doesn't look close to mod..
What is your fdr in the 4wd buggy? I would suggest sensored only as well, but most people don't need to add any extra timing with mod motors offroad. My setup in a b44 would hover around:
Sensored only
6.5 tekin sensored motor with 12 degrees on the can
10 to 20 degrees of boost
start rpm 10k
end rpm 30k
FDR around 10.5
Sensored only
start rpm 10k
end rpm 30k
FDR around 10.5
Sensored only
start rpm 10k
end rpm 30k
FDR around 10.5
Sensored only
start rpm 10k
end rpm 30k
FDR around 10.5
Final drive ratio? I'm not sure
Sensored only
start rpm 10k
end rpm 30k
FDR around 10.5
Sensored only
start rpm 10k
end rpm 30k
FDR around 10.5
