truggy rc8te 6s lipo witch battery to run
ok i got a rc8te with a rx8 an tekin 1350kv motor i have my truck set up for two 6s lipos. i run a 20 min main so i need a total of about 6000 mah but i cant decide what battery to get i was thinking max amp 3 year warrenty sounds nice.but the price sucks a guy at my track runs some cheep ebay brand winfore like 50 to 60 bucks a battery an i have been runing his batterys in my truck. they work but i dont know. so tell me what u guys are running in your truggy
ps one more thing i was tinking about was running two 6500mah 3s lipo in seres the reason for two batterys is weight balanced but if u guys have hade luck with one 6s around 6000 mah let me know give me what ever input u got
Hyperion do not make any more packs over 5000mah due to shipping regulations. Maybe one of there older 35C one's but the new 45C they don't. If I were you I would try these. Work absolutely great and at a great price.
http://www.hobbyking.com/hobbyking/s..._25C_Lipo_Pack
http://www.hobbyking.com/hobbyking/s..._30C_Lipo_Pack
Terry
Terry
Will 30C be okay on a RX8 ? I was going to call Tekin because I heard that 40C is recommended for the RX8 / 1900 KV
I was thinking about going the Turnigy route as well but didnt want to chance it.
http://www.hobbyking.com/hobbyking/s..._hardcase_pack
i run a 2600mah 6 s on my rc8be and get 12 minutes easy. if you have a pack you can get a base line mah/per minute that you use, you can find out what size battery you need. I figure you will use 220-250 mah a minute if you dont blow the tires out in every turn. That would put you needing a 5000-5500mah 6s. I have the nano techs and love em, light, good punch. my 2650s actually weigh 388g vs the 399g advertised. and as far as battey fit, throw a Slosi trey on it. JMO
I run 2 venom 8000 25c and have no problems get 18 mins but could stretch to 20 if i played with the current limiter and voltage cutoff right now it's 3.75 because I don't have a hotwire.
