b44 clack clack noise help!!
Just got a used b44 and when i hit the brakes it make a clacking noise. what could this be? It does it make any noise when i floor it from a dead stop. only when i brake.
I checked front and rear diff. they seem fine but i dont know. any help
Super Moderator
Trader Rating: 31 (100%+)
One "clack" or multiple?
Super Moderator
Assuming the outdrives, CVD's and front'rear drives shafts are all in fair shape I would look at the diffs. Have you had them apart or do they just feel ok?
If it's when you hit the brakes it's probably the front diff gears. One of the teeth is probably broken. No big deal. Just rebuild it and check that the diff is shimmed so the gears of very little play when you put it back together.
As long as it's apart you might as well change the diff balls and thrust balls and rings and washers. You don't have to, but if you don't at least take it all apart in there and clean it up and re lube it.
For future reference, when the gears give out in front you will generally hear it more on the brakes and if the rear gears go out you will hear it when you give it hard throttle.
