Traxxas to Deans adapter in rc car?
Would anything be wrong with using one of these adapters inside the car itself ? Would the connection be weaker or will it use more energy or anything? Is it safe... i guess thats the main question to ask. I have deans on all my other cars and figured i could get an adapter and use it with all my deans batterys in my slash that has a traxxas connector on the esc. Just trying to avoid pulling the traxxas connector off of the esc itself if i don't have to. The battery i have with deans is a 3s lipo i want to put in the slash w/ the adapter since the lipo has a deans already on it and i want to use it in my other cars as well. Also how about for charging? I've had no problems with adapters on nimh and nicd packs but never used one for lipo always a direct connection (just curious even though i wont be doing it)
Using an adapter will increase resistance since you have 2 plugs instead of 1. You will get higher performance in both top speed and run time by going direct without an adapter.
This is not a big deal if you are just bashing around. It is also not a safety concern as long as the adapter is soldered well.
-Austin
-Austin
Super Moderator
Trader Rating: 31 (100%+)
-Austin
-Austin
As far as I know its recommended only for charging not for running. Im shure you can run safely and wont knotice any difference in you RCs performance. I suggest buying a soildering gun and just using one type of plug. Either one would be fine. Being a Traxxas guy I just use Traxxas plugs. Once you cut the Trx plugs off you void there lifetime warrenty.
