Simple Green Safe on Plastic?
#16
i use a compressor with a toothbush & wd-40 & it makes it like new.
#18
"I have a T3Team. I race with it in my back yard, I gets very dirty. I was wondering what to clean and how to clean it.
Use a paint brush or what ever brush will fit the area you are working on first to get the major dirt and grime out of the truck. When you want to really clean the truck you will need to remove the engine and electronics, then you can clean the truck with a basic household cleaner like Simple Green, 409, or an equivalent product. Be careful! These products have water in them so when you are done cleaning make sure you dry all the steel parts. You can even coat the steel parts with a light coat of WD40 or help prevent any rusting. Use a motor cleaning spray to clean your motor and just dust or blow off the electronic parts in
your truck."
That is from Team Associated's website. It's from their RC10T-T3 Q&A.
your truck."
#19
I do not think Simple Green attacks CA (super) glue. About the only thing that works on CA is acetone.
As for a 'clean dry surface' ... it doesn't leave a residue if that is what you are wondering. Of course this depends on rinsing with plenty of water...and plenty of waters does not equal a 'dry' surface After a good rinse, I use an old towel to get most of the water and then let things air dry for an hour or two.
Also, when washing wheels/tires. Be careful not to get water into the tire by way of the breather hole(s) in the rim. A wheel can become VERY unbalanced if a portion of the foam insert is soaked. I make sure to cover the breather holes with my finger when washing tires.
'nuff said,
MX4
Originally posted by Cain
Does anyone know if this stuff attacks the tire glue? Also, does it leave a clean dry surface ... ?
'nuff said,
MX4
