TAMIYA TRF502X Thread
#587
TRF 502Xs
For those of you that don't have access to the "Bookface" TRF Off Road Buggy page
Here is the completed project. Paul Sims a BEZERK R/C did this work and is the one who sells the conversion chassis kit
Comes with 4mm front and rear towers, 2.5mm upper decks, 3mm lower deck with no openings ( completely flat ) 3.5 mm longer and 10mm narrower as well ( same width as the TRF503 ) milled pockets, adjustable shorty battery tray to adjust the weight for optimum balance, floating servo mount brought over from the TRF503 and can be flipped to either side depending on what chassis balance configuration you want to use ESC behind the motor or esc in front of the Shorty battery. Chassis balance is a 46% Front & 54% Rear Bias ( similar to the 503 bias which is 47% Front & 53% Rear ) Also this chassis kit makes the TRF502x very light...as well for those of you that run spec classes.. 13.5 ect ect..
#590
#591
Nice. Since the chassis is 3.5mm longer does this cause an issu with the prop shafts fitting properly? (edit) oh, I see now, it is explained on Bezerk R/C web site.
#597
#600
