rc8t front tires ballooning
rc8te setup. reverse motor mont. motor on front left side. two 6s lipo one on each side in rear my problem is i keep lifting the front end of the ground when i get on it but as soon as the front end lifts all my power is sent to the front tires then it slams back down then the rear end will get power again an do it again. anyway my thoughts were diff oil not right or because u have to reverse the center diff to change the motor mont
actually looks like a HHH chassis'd VE8.
Yep, that's no RC8TE.
yea sorry that pic was the wrong one. an yes i do have a tekin 1350kv truggy motor an all i do is race with it. its set up right now 10/10/10
I went from 7K to 3K center diff fluid in my RC8T to eliminate front wheel balooning.
Increasing the center diff enhances the 4WD effect and would put more power to those front wheels that have way less traction.
You could also increase spring rates and shock oils to change how the truck transfers weight on-power.
From what I have read and learned on the track, that is backwards. If your front wheels are getting too much power and tires are ballooning too much, than you need a thicker fluid to keep more power at the rear wheels. But it sounds like you may have too much power to your rear wheels, causing the front to lift up. To stop the front from lifting up you want to go to a thinner fluid in the center.
yea i have been trying a few different things an yes i have two 6s lipos in parral witch is 22v
