4wd 1:10 Buggy Suggestions Needed
Looking to add a nice 4wd buggy to compliment my current 2wd Kyosho RB5 (which I might add is a great buggy). It will be used primarily on an outdoor dirt track here in SoCal. I would prefer a kit requiring relatively low maintanance, and good durability (who doesn't, right?)
After lurking around this forum, the following come to mind:
Kyosho Lazer ZX5 SP
Tamiya Durga (DB01 chassis, enclosed drivetrain)
Team Durango DEX410R
The track I will be using is pretty dusty, so I'm a bit concerned about junk getting in the belt system, and/or the gear mesh. The enclosed drivetrain on the Durga would eliminate that, but I'm not sure it's up to par with the other two. Maybe it's not as big of a deal as I think. The Kyosho and Durango seem like higher quality kits, but appear more "fragile"
Anyway, any thoughts would be appreciated, and feel free to suggest ANY other buggy I didn't mention.
Thanks!!!
SoCal
Kyosho Lazer ZX5 SP
Thanks!!!
SoCal
dount count out the ZX-5 FS. or even the new FS2. The kyosho shocks soak up the bumps on rough tracks better than anything else on the market
Any thoughts on the Schumacher line-up, or possibly the new Caster?
We had about 4 schuie cars at hour indoor track last winter and they all seemed to FLY. You may want to check into the CAT SX2 thread and see their oppinions.
B44 all the way..
Just make sure that you fully-seat the gears when you assemble the car or you will have issues. Read the Oople review first because he has some very specific tips during assembly.
One gotcha for US drivers is parts availability. Someone said on the DEX410 forum that A Main Hobbies has a limited time exclusive on Durango parts so none of the other US stores are able to carry them yet. Though I buy most of my stuff from amain (and RPP) I've found that a lot of the 410 parts have been out of stock since the product was first released. I'm sure that's Durango's fault but it's something to be aware of. Ordering parts direct from Durango (which has everything in stock, strangely) requires a minimum $30 shipping fee.
If I had it to do all over again I would have skipped the 410R and waited for the full spec 410, even though it's more pricey. I've already spent more than the difference buying the hop-ups ad-hoc. The 410R was an impulse buy while I was visiting Nor-Cal hobbies and the 410 wasn't shipping yet...
Thanks to everyone for all the helpful suggestions
It seem as though whatever I end up with will most likely require a saddle-pack LiPo. I'm real familiar with the stick packs, but have no idea what I'm getting into with the saddle-pack. Your thoughts and/or recommendations would be appreciated.
Thanks again,
SoCal
Thanks again,
SoCal
Saddles are the same.. there are just two of them.. go to amain and look at them (by brand) and get an idea.. the Proteks are probably your best bet.. the have a decent mAh rating and high C rating, while still able to fit in every chassis your debating on (even the durango).. but remember if you don't want to get saddle there is always the very capable Schuie CAT SX2 and the Jconcepts BJ4 (non worlds).. I believe jconcepts started reselling the kits on their site (may not be available).
