how do you know what kv??
#16
Really good information here. I too am a nitro guy and am glad I stumbled into this thread.
My new Losi 8IGHTe 2.0 race roller came with the Excelorin 1700Kv motor (they used to come with the 2100Kv), so it appears as though I should be looking at 5s rather than 4s. Good to know. Either that or I could use 4s and go up in pinion size but then it appears as though I'll lose efficiency/durability.
#17
so if 2050 is my motor choice...
what are the best overall battery choices?
3s, 4s, or 5s ?
im guessing that the cells make up the power?
like a 5000mah 5s will be dramatically more powerful than a 5000mah 3s?
is 3 or 4 cell sufficient for a tekin or castle 2050 system?
3s, 4s, or 5s ?
#18
You need to do KV*voltage, that should between 28000 and 35000. That's the optimal RPM range.
You need to chose a lipo that machtes your motor KV.
#19
or play with the ESC a little and really whip up on some Nitro buggies.
You can't go wrong w/ the 2050, check out StormerHobbies they had a pretty nice deal when I got mine. PLus they are for sure the new case's!!!
As for the rpm I find that keeping the rpm between 22,000 and 28,000 has better runtimes, cooler temp's. It has plenty of juice, and very smooth.
#20
#23
Yea i understand, but you are advising to TS to run 3S 2050kv in his buggy which is not enough for out door tracks. Indoor is an other story.
#24
If you need more speed then just gear up for a longer track. Beside's that the buggy combo is ideal for a 1/10 SC Race since they are usually on a smaller 1/8 scale track. Never seen any high temp's and still run the stock slipper that came with my PE. I did upgrade to Tekno axle kit's so I would be safe on the axle's, but never had a problem w/ the stocker's either.
You may need to have a high kv motor to prove some point, but I am cool with what get's me the most enjoyment and the best result's for me.
