RC8Te
RC8Te
So I am planning on purchasing a RC8T and converting it or a Te if i can find one. So I'm looking at a Tekin RX8 ESC and I'm a little unsure what motor i should get. I'm most likely going to running on a track thats pretty big with allot of big jumps, i know different gearing can do allot for me but still would like to get the right motor to start with.
Thanks for any help!!!
R/C Tech Elite Member
Yea I just got one my self I run dual 6s an the rx8 an truggy 1350 motor great power an 40 min run time
kv is kind of weird unit but it really means RPM per volt. 2250kV doesn't necessarily have more power than a 2050kV, just rotates at a higher RPM. You just have to gear them appropriately. Lower kv motors with high voltage batteries (5/6S) are more efficient because you are generating equivalent power at lower current (Voltage x Current = Watts).
I just got an RC8Te a few weeks ago. I love it. I run the Castle MMM with the 2200kv motor. It's a beast. If you are going with Tekin and running at a big track you will probably want the 2000kv or maybe 1700kv on 4S. The 1700kv will get you more run time though. If you are going to run 5S or 6S, then go with the 1550kv or 1350kv.
TT2362 4038 1700kv
TT2363 4038 1550kv
will be a good choice then.
pinions help
HAY GUYS I HAVE A RC8te and cant find pinions for it. Do anyone of you guys know where i can get them, and what kind to get. right know runnig a 2600 momba with 16-50 and gets to hot. thanks
pinion help
for got 4 cell lipo thanks
Im running 1550 with 4 cells and its perfect with the rx8. Sold the 2200kv as it easily over powered the truck. Your better buying a lower kv motor and putting more voltage to it, than you are putting less voltage to a higher kv motor.
http://www.amainhobbies.com/advanced...s=mod1&x=0&y=0
pinions
thanks Blade
Guys we cant let this thread die, Lets see your trucks. Heres mine
My favorite motor on 4s is the 2000kv followed by the 1700. The 2000 is great onl 95% of the tracks. The 1700 is good if the track is slippery.
