Slash Anti Roll bar?
I have a 2wd open short course slash with Integy piggyback shocks and M2 caliber rear tires... I have heard that I should possibly look at getting an anti roll bar set up for the slash. Has anyone used these and how exactly does it work?
I assume you asking about a sway bar setup. This is a stiff bar that is mounted from lwr suspension arm to arm that limits chassis roll or lean as it turns. They are usually on both front and rear. A good kit may come with 3 diff bars to provide some stiffness adjustment (hard, med and soft).
That's with the shocks totally out as far as I can get them and with leaving them completely open (no spacers or the equivalent.)
Lots of info on the subject -
http://monster.traxxas.com/search.php?searchid=1579435
I don't use one, but I'm not racing either.
The only one that I had ever seen was an from strc and it was for the front only but that was several months back and I did not like it I ended up going with losi 60 all around if I was out doors and losi 50 all around indoors! also tear you gear diff down and throw 100k diff lube in it and seal the out side with silicon so it wont leak out but you will need to change ever so often depending how much you race... That will keep on power to your rear wheels!
