there a way better pack ive seen them used in rc losi 8 you can charge them at 10c thats alot my son uses them in his helicopter 45c with 90c burst mostly used for heli but awesome in car uses they are 75 dollers for 4s1p 5000 shipping from turnigy
Hyperion and Thunderpower have been using this nano tech for some time and there may be others - basically 'nano' refers to the particle size of one of the lipo media components. At this small uniform size, lipo performace is increased in several diff ways - lower IR, increased C rating and increased C charge rates. Any of the 5C+ capable lipos are (and have been) all using it and HK/HC is just catching up. Since they adopted the name, it looks new, and like they're the only ones using it, but its not.
Here's a snip from an older Hyperion page that mentions its use in their line of G3 lipos -
"BACKGROUND
The G3 packs were the first to introduce the new Hybrid RS (rolled/stacked) construction technology, super-fine "nano" substrate materials, and an extremely rigorous Quality Control and cell matching process, in order to guarantee you not only superb performance, but also very tightly balanced and long-lasting packs. No other brand has yet exceeded our specifications - regardless of their marketing claims - nor value pricing. Hyperion makes a point of bringing the best to market, at the lowest possible pricing for you.
G3 deliver the highest voltage and flattest discharge curves under load, which makes them the best performer you can buy. And tests have shown that at the 70%-discharged point in flight, they are delivering as much as 40% more power than previous generation LiPo.
The fact that they can be safely charged at up to 6C rates with absolutely no negative impact on lifespan - for charge times as low as 10 to 12 minutes - is just icing on a very tasty cake. (G3 have been certified for 6C without cycle decrease. However, charge time difference between 6C and 5C is negligible (or often zero) due to CC/CV curves, so we believe 5C to be the ideal fast-charge setting for quality Lipo)."
I have two of the turnigy nanotechs (45/90c 5000mah) in my 8ight-T. They work great so far. Lots of punch and run time, they fit the battery tray perfectly.
