Old 04-18-2011, 07:56 PM   #2476
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
That's a sweet write up. I just had mine apart to replace the outdrive hubs and this is pretty much the sequence I followed except for the 400 grit on the dif washers. Good info.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 04-18-2011, 08:19 PM   #2477
Trader Rating: 32 (100%+)
the K springs are about 1/4 in shorter. you can get the ride height where ya want but it pulls the adjusting collars down a bit. I prefer to have them closer to the top....not sure why just picky I guess. I have not seen any durango springs around here....
I will say that I have 2 stock green springs that dont hit.....but I had to sort through a few sets to get them.Seems odd to me that this is an issue. Ive built lots of different shocks and these are the only brand to have these issues. bummer! Maybe it doesnt matter for performance on the track but it bothers me to hear it when adjusting on the bench.
Quickstang is offline   Reply With Quote
Old 04-18-2011, 08:35 PM   #2478
T&D-RACING's Avatar
Default Team Associated Offset Spring Cups (B44)
If you run out of thread adjustment for your collars on your shocks- try some offset b44 spring cups.
Team Associated T4.1
Team Associated B4.1
Team Losi 8ight E 2.0
Team Losi XXX-SCB
T&D-RACING is offline   Reply With Quote
Old 04-18-2011, 08:42 PM   #2479
are they taller then the b4.1 cups? those stand up pretty good ..
Old 04-18-2011, 09:06 PM   #2480
T&D-RACING's Avatar
Sorry they're the same -I had to look it up to find out.
Team Losi XXX-SCB
Old 04-18-2011, 09:08 PM   #2481
no prob! Thanks for looking !! Im gonna play with the k springs and get my K shocks all built. their shocks were always butter smooth.
Old 04-18-2011, 09:11 PM   #2482
916bdogg's Avatar
Questions??
Mods that need to be one ?
916bdogg is offline   Reply With Quote
Old 04-18-2011, 09:30 PM   #2483
inconceivable's Avatar
All this talk regarding shocks has me thinking. I've built and run several dozen on and off road cars over the decades, however these V2 shocks have me stumped. Just started running the B4.1 using Cav's setup but can not seem to get these shocks the way I'd like. If this makes sense, they seem to me to react like a shock that's missing oil, all the action seems to come from the spring with little action / resistance being provided by the oil. I've even watched the V2 video on the web site but this is exactly how I'm building / maintaining these shocks. Any secrets into getting these shocks setup are appreciated. PS, very cool write up above regarding diffs.
"And now the Matador shall dance with the blind shoe maker"
"America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt, 1936"
inconceivable is offline   Reply With Quote
Old 04-18-2011, 10:24 PM   #2484
Andy Davis's Avatar
Ive noticed this too, browns seemed a little to springy when I raised and dropped the front end on the table. I went from a #2 piston to a #3 and black kyosho spring, this did seem to help, not as much bounce on the front end. Next Ill go up a tick on the oil and get the red front kyosho springs. It also help alot with my corner entry and mid corner steering.
Andy Davis is offline   Reply With Quote
Old 04-18-2011, 10:32 PM   #2485
TheModTurtle's Avatar
I don't really notice it too much. I use a heavier oil than most others. I usually go with about 32.5 wt
Think quick but not... Almost like being fast... Asleep..
TheModTurtle is offline   Reply With Quote
Old 04-18-2011, 10:37 PM   #2486
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Shock Rebound ?s
Has anyone else noticed that the V2 shocks seem to build up more rebound over time? I know when I build them and work the several times they will usually have about 1-2mm of rebound in the. After I take them off the car at the end of the weekend they seem to have almost 1/2" of rebound.
I feel that they slowly pull in more air over time and cause a greater rebound. I have started "burping" my shocks every night before I race. I pull the bleeder screw off and push the shock up and then insert screw back in to remove some of the air.
Anyone else found this to be the case? I am not ripping on the shocks, they seem very smooth and work well, just concerns me about the amount of rebound they build up over time.
Thanks in advance for the help and thoughts.
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 04-18-2011, 10:41 PM   #2487
Hmmmm I havn't noticed that (but then again, I hardly ever check my shocks ). Helpful idea on how to correct the situation though
Old 04-19-2011, 02:54 AM   #2488
Tech Legend
Wild Cherry's Avatar
Happens when the O-ring for the cap is worn out or cap not tight enough ...
Always used the Ae shock wench to tighten caps , hand tight not good enough..
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 04-19-2011, 06:11 AM   #2489
JFuel11's Avatar
Default Great Idea
The shocks are pretty new, so I am going to guess that I am not getting the caps tight enough. I will try tightening them down a bit more and see if that helps.
Sponsors:
Old 04-19-2011, 09:13 AM   #2490
mellow's Avatar
Trader Rating: 16 (100%+)
Yep, I tighten the crap outta mine with the tool.
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
