HELP: How To Replace Motor Bearing
Last Sunday I went for a race with my SCRT10 in wet track (and I won 1st place ). Two days later I've found that my motor bearing was shot . Today I had the motor dismantled and try to find out how to pull the bearing safely off the motor. Any ideas? Because I'm way too scared ruining the motor case. Thanks...
The biggest thing to pay attention to is tapping it back in straight.
If it spooks you to do it. Send it in, and we can take care of it for you.
[email protected] for a quote.
bearings
+1,very easy,just take out the armature slowly and just tap it out lightly and should pop right out.then carefully pop the new one in,my buddy had to do this to the silver 4.5 in his ofna hyper 10sc,that's why i bought the ballistic because it had bigger bearings i think.
Simply just tap the old one out and tap the new one in.
I assume your talking about the bearing in the end bell .
Whats the best way to tap it out. Use a solid wood dowel.
this will prevent you from gouging up the area where the bearings
rest in. Some people use metal , but I prefer wood ,it prevents other
headaches.
Dynodan22
headaches.
Dynodan22
be real nice to ur mrs. make her dinner and after u send her off with a nice fruity fun adult beverage or glass of 'vino to watch her fav show. knick back into the kitchen and turn on the oven and heat that block up nice and hot to make those bearings drop out much easier.
R
R
whoops thought i was in the nitro forum. granted the above prolly still can apply in helping ur cause.
R
R
and to help get them back in toss the bearings in the freezer for a few hours or a day and then quickly slap them in. I always do this with the bearing on my fourwheeler and it makes them way way easier
