Hot Bodies VE 8 some questions
Hi Need some help on the VE 8
Just purchased all setup with a MM 2200KV running the stock 50t spur and 5000mah 2s(2).
I have a few questions,
1. Have installed a 18T pinion but for some reason the screw keeps unscrewing even after using thread lock. How to avoid
2. The battery is tooo close to the pinion and has actually gotten a bit shaved off luckily its a hard case. Help.
3. I have installed the optional break kit but since the ESC goes into the channel 2 where the break servo is suppose to go i cannot use the break running a traxxas link. Please suggest.
4. Where can i get a alluminium chassis.
Also please suggest some upgrades on your experinces.
Please advice i would be really greatfull
