10.5 motor recomendations
I was about to pick up a 10.5 motor to go into my 2wd SC10. I already have a Tekin RX8 so I was thinking I would try the Redline 10.5. Anyone have any experience with this motor in a 2wd?
What do you think is the best setup?
I dont want to have to buy an RS when I already have an RX8. What do you think??
not sure that is a legal speed control for 1/10 scale if your racing?
So pretty sure an 8.5 motor on a tight track is not an option?
I would say maybe with the 14mm HT rotor and a mild throttle curve.
I like the ht rotor's in high kv motor's. Since the bigger rotor lose's some
rpm , but run's so much cooler.
I have a 8.5ss 5800kv that I put my 13mm rotor in for bashing around. It
will pull the wheel's up on a 2s w/ the RS in sensord mode.
throttle control would have to come into play I know alot of the guys a race at run 8.5 and 9.5 mainly because the 10.5 are getting hot from gearing them to much?
ya everything I run seems to get hot. I play with gearing and if its not the motor its the esc. I suppose an 8.5 wouldn't really have this issue if you set it up mild.
The one question I get asked is do u get marshalled often? If u do gear down if You don't gear to the moon
