c rating ????
you will notice a difference, you will have more punch and depending on your setup you could run cooler too because your now pulling more amps that the battery cant produce
personaly a batteryis a place you cant skimp out on to get a quality pack you got to spend some money. i curently run orions and love them!
I hope this helps you out!
There can be a noticeable difference in punch and overall power-speed in 1/10 scale. Generally not as noticeable in 1/8 scale, as they tend to overpowered or at least nearly so anyway. For 1/8 scale it’s mostly about keeping battery temps down as mentioned.
Higher C rates mean more punch, less amp draw and cooler, longer runtimes in the lipos
HIGHER C ratings are a must in 2s. But I dont think they are nearly as important in 4s and up.
