Old 05-30-2004, 08:46 PM   #1
corvettecrazy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to corvettecrazy
Default keeping dirt to stay on dirt tracks
for those of you who have been to, helped build, or built dirt tracks how do they keep the dirt in place and packed down on the jumps??? I have tried building dirt jumps but after a tank or two they seem to just fall apart. Whats the secret to building jumps, ripples, and banks that don't become just another pile of dirt?
corvettecrazy is offline   Reply With Quote
Old 05-30-2004, 09:01 PM   #2
wild gopher's Avatar
Trader Rating: 39 (100%+)
roll them with a water roller until they are hard packed and use plenty of water. Another factor to consider is the type of dirt being used
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 05-30-2004, 09:47 PM   #3
Default Clay
We are using clay. With a bit of sand. The clay will harden if you pack it. When the clay is dry rent a plate packer, will work nice to shape the doubles and other jumps. They are usually very cheap to rent and this will pack the track very nicely. The sand mixture (not too much) will keep the clay from really hardening and balling up. It will keep it loose on the track. So for the jumps use only clay. It will pack and stay right there. For the track us clay with a bit of sand so it stays loose. Good luck
Smooth is offline   Reply With Quote
Old 07-08-2004, 07:50 PM   #4
basementLOSI's Avatar
Send a message via AIM to basementLOSI
Default Re: Clay
EXACTLY how we did out track. For jumps we just run over them with our trucks and after a while they pack down. For jumps that are accesible to a tractor, we run a roller up to them.
basementLOSI is offline   Reply With Quote
Old 07-12-2004, 06:54 PM   #5
I have never built a r/c track, but I have built plenty of dirt bike tracks. The plate compactor & clay will most likely be your best bet. You may also want to build side braces out of plywood and "stake" them in place on the sides of the jump. Just make sure they are a little shorter than the actual jump.
joe-m is offline   Reply With Quote
Where are the Off-Road Dirt Tracks in NJ? Captpete Track Locator Forum 13 08-24-2008 07:22 PM
looking 4 dirt oval tracks nc tn ga lowridinjuggalo Track Locator Forum 0 06-29-2008 07:42 PM
any dirt tracks in sac,ca bigorange Track Locator Forum 5 02-15-2008 12:24 PM
Dirt Tracks! Tmav55 Electric Off-Road 9 03-05-2004 03:59 PM
Any dirt oval tracks in Tn ....? Donnie-D Track Locator Forum 0 06-09-2003 06:16 AM
SEO by vBSEO 3.5.0
