Old 07-12-2010, 05:11 PM   #1
wiscnitro's Avatar
Trader Rating: 22 (100%+)
Default SC10 front & rear traction problems
My SC10 is set up with a 10.5 and GTB goosebump rear tires stock fronts,silver springs all around 20w rear 30w front shock oil I believe 4deg rear toe batter mounted to the rear .our track is dirt. The truck is verry stable over jumps and landings but on and off power steering has a bad push and I can't get beyond half throttle on the streight I lose traction way to easy even when I squeeze into it. What can I do for either end
Hold my beer and watch this! :)
wiscnitro is offline   Reply With Quote
Old 07-12-2010, 05:32 PM   #2
Trader Rating: 9 (91%+)
I use 40/30 weight, gold fronts green rears. I have everything set straight as as possible with a camber/protracter gauge, I also run calibers all the way around, running the bowties in back and stock in front is going to give you on power push. I also run 3 limiters in the back and none in the front. And 7000w diff oil. Mine hooks up better than I could have ever hoped for.
interplanet is offline   Reply With Quote
Old 07-12-2010, 05:34 PM   #3
forgot to mention I am running a 13.5 with 87/21 gearing
Old 07-12-2010, 05:35 PM   #4
+100 on the diff oil...... and the shock's I run close to the same.
Hook up is all to important!!!!!!
gottabaja is offline   Reply With Quote
Old 07-12-2010, 06:01 PM   #5
wiscnitro's Avatar
I'm ok with a light on power push then I don't have to wory about the rear steping out when powering out of a turn or lineing up for a jump I'm gonna try the diffrent springs the off power push is so bad right now
Old 07-12-2010, 06:26 PM   #6
RDOUBLEDAY's Avatar
I find the stock tires dont work that good in the front. Get some aka enduros for the front. Also i run black springs up front and greys out back. Works great.
Mugen Mbx6 Eco .
RDOUBLEDAY is offline   Reply With Quote
Old 07-12-2010, 06:34 PM   #7
wiscnitro's Avatar
Is there a spring chart available? I'm guessing the silvers are too stiff so I don't know what the next step down is on the springs and there are a few that use stock front tires and some that use aftermarket and from talking to other racers they don't notice too much of a diffrence
Old 07-12-2010, 07:18 PM   #8
chonchachencho's Avatar
Sometimes i find that running on loose tracks you want to soften up your springs/oil.. it only makes sense, sure. but it isnt always true. the best think you can do is drop in some heavy weight and test. Also, one thing that is always overlooked is ride height.
Adrian Ramos
IBEW-SPEEDTECH RC
chonchachencho is offline   Reply With Quote
Old 07-12-2010, 07:23 PM   #9
XxE-ReVoRaCeRxX's Avatar
its best if you look up setup sheets from pro drivers or ask the best drivers at your track and maybe get as close as possible to their setup.
-Justin
-Losi Ten-SCTE 4X4 Tekin Rx8/ Trinity 5.5t
-SC10.2 FT Speed Passion Reventon Pro/ Trinity d3.5 7.5T
-SC10 FT Novak Havok SC/ Ballistic 17.5
-Backyard track / Action Hobbies / Long Island Raceway Lindenhurst / Gilligan's Raceway
XxE-ReVoRaCeRxX is offline   Reply With Quote
Old 07-12-2010, 07:26 PM   #10
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
I just took my FT SC10 out sat and it had the same prob you did with on/off power push. I switched to bowties up front and it was a night and day difference.
Yeti AS3 is offline   Reply With Quote
Old 07-12-2010, 07:32 PM   #11
Jstall7543's Avatar
Or switch to a ball diff. The new sc10 comes with one because it just works better IMO!
I have found the sc10 rear does walk out under power. I added some -expo to my throttle to smooth out the power. I found that the grease that comes in the diff works best, heavier oil only makes it posi more making it drive worse. 4 deg rear hubs might be to much, I'm running 1.5 deg. with bowtie sc's and it will wheelie from time to time. Your best bet would be less power and higher gearing or buy a 4x4 and never look back!
RC is a way of life and a ridiculous hobby.
Ridiculously Fun! Subscribe to my YouTube Channel! Or ELSE! Hehee! http://www.youtube.com/user/Jstall7543
Jstall7543 is offline   Reply With Quote
Old 07-12-2010, 07:38 PM   #12
brickshouse's Avatar
more rear traction :more toe in rear, limiters in rear shocks, lighter oil and or springs in rear, drop ride height in rear, less anti squat shim more front traction: more toe in, 25* caster blocks, lighter oil, softer spring, limiters in shocks, drop ride height, bump steer washers, you can always play with the camber a little with both as well or try a little lead weights and battery position, tires are 90% of setup though.... good luck go to ae website, then racing, then setups, gotta a few different ones, just try to match the conditions of your track to the setup they have, will put you in the right direction. 4* in rear prolly too much....
Second place is first loser, and a special thanks to 8lb. 6.oz newborn infant jesus. Gotta love credit cards, buy anything you want and simply make a small monthly payment for the rest of you life. DK Concepts---Outsiders RC---F and R Metals---AE 4 LIFE SON---U LIKE TO SEE HOMOS NAKED???
brickshouse is offline   Reply With Quote
Old 07-12-2010, 08:16 PM   #13
Fordplay's Avatar
Send a message via AIM to Fordplay
stock fronts
You answered your own question. You need better tires up front. You can get away with the stock tires on some tracks (even work great at a few) but for the hard packed tracks, your going to need something softer. IMO
Jeff Gill
AKA "Rockcrawler"
SC10 Tekin RS/17.5
Fordplay is offline   Reply With Quote
Old 07-12-2010, 09:17 PM   #14
RDOUBLEDAY's Avatar
Hard too soft,
Red-Hard
Gold-Med-Hard
Blue-Med
Grey-Med Soft
Silver-soft
Green-Softer
Black-Softest.
Mugen Mbx6 Eco .
Old 07-12-2010, 09:27 PM   #15
RcRacing4Ever's Avatar
I have a 8.5 in mine...
30 degree caster blocks
1 degree toe out & 1 degree camber
Front blue springs & 40 oil,3 limiters
2 degree rear losi hubs & 1 degree camber
green/silver rear springs(depending on track) & 35 oil,2 limiters
M3 Calibers All the way around
Battery in stock location(lipo)
Added 1 1/2 oz. to the truck,3/4 around servo & 1/2 in the center
It works for me...hope that helps ya some
- Associated Sc10 -
- FT TC5R -
Sponsors *My Wife & My Wallet*
RcRacing4Ever is offline   Reply With Quote
