losi coversion kit or castle creations conversion kit - for losi 8ight 2.0?
#16
post#3060
http://www.rctech.net/forum/electric...e-4wd-204.html
#22
The losi mount is designed for 4mm sized motor mounting screws (Xcelorin).
For it to be right, its best to drill and tap the motor endbell to 4mm screwholes.
Also, the support that goes under the motor is actually designed for the Xcelorin as well, not the Castle Monster.
I own both, IMHO Mikes mount and tray are really all you need to get going, and I feel they work and look better than the Losi Kit.
#24
How well does the CC conversion layout fit under the losi e body LosA89097, the batteries are my main concern with them standing on there side but the ESC looks like it sits very high.
The equipment i will be using ip 5000mah 7.4v x 2 with a monster CC esc.
Thank you in advance
