Gearing setup traxxas slash 2wd
well i have the new fuze Brushless SC combo and my gear is 16/83 it gets hjot after about 10mins and also its on the advanced timing setup. it seems whatever i change the gearing to it gets hot. i dont know what to do can someone plz help me it would be greatly appreciated
I have a Tekin Rs /8.5ss Novak and I am usually at 3 lights on the
ESC and around 140 on the motor. My gearing is 20/90....by the gearing
calc I am 16.47 undergeared, but the gearing calc does not take into
account any advanced timming or boost timming. Which I have been
told can change your FDR.
I will say that it is fast enough...but at the same time it could be
faster. I am slowly getting it fine tunned..
What size motor do you run........Timming, is it a end bell adjustment
along with some ESC advanced timming. That can really heat up a ESC.
Also does your have a "current" limiter...I got mine down to 96% which does
not affect performance just how much "overflow" of juice is not used by the motor and turned into heat.
You could try to re-set the setting's to default and see what temp's you are getting. I did it that way. Then slowly tune it from thier.
My Slash is MM Pro 4600 powered w/2s 5250; its setup 15/86 and runs about 160 +- if that helps any.
Castle suggested 14/90
it might be on the Castle site but I spoke with a tech on the phone.
hmmmm well im gonna order some pinion gears and see how that works thanks for ur help bowl thanks are given: Leroy1234p
Check out the Robinson pinions. 1 thing I noticed was the pinions purchased individually aren't as noisy as the ones in sets (15-25, 16-26) I don't have the 14t but the 15t,16t runs fine. Glad to be of some help!
