Uses of SHOO GOO!!!
I use Shoe Goo to line the outers of my bodyshell and the areas where the body posts are. Cracked edges are a thing of the past
Also use it to mount my antenna spring onto my receiver antenna tube. Works in slightly coating a little shoe goo to the screws that turn into plastic parts to give a better hold. *Just a little bit*
I use Shoo Goo on/to.....
Repair bodies
Reinforce crack prone areas of bodies.
Further secure servo tape mounted electronics. Just a short bead on the edges. Sometimes stuff still squirms too much with just servo tape.
A dab on half a screw head and part so the screw wont loosen.
Balance wheels/tires.
Transponders. Reinforce the wires where it comes out of the case. A small dab half on the wire and half on the case.
Secure antenna tube to mount.
Repair bodies
2 Decades
I've been using ShooGoo for more than two decades and i still have the last tube i bought ten years ago. thumbs up! +++AAA
First i was using it for my running shoes sole repairs, i was a runner those times, then i found it more usefull to our hobby, its a great all around use, sob! sad to say its no longer available here in Saudi Arabia.
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Did you read my post from the other thread?
Anyhoo. One of the most recent things I did with shoe goo was to re seal a transponder after doing a wire replacement.
I had to cut the back of the case off. CAREFULLY Dremel out the epoxy to get to the solder joints, and re solder fresh cut ends to the board. Once I was finished, I re sealed the transponder with a bit of goo and a piece of .030 Lexan. One the goo dried, i trimmed and sanded the edges of the Lexan for a clean smooth look.
I liked to shoe-goo my hinge pin e-clips so they didn't fall off. You could just peel it off when you wanted to remove the e-clip
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 42 (100%+)
I have built complete prototype shells with shoe goo constructing things sheet metal style.Will post a pic.
How long does shoo goo last? My tube seems to no longer be sticky/tacky and it isn't that old. I needed it recently to fix some bodies (and to reinforce some new ones).
I have a tube that I know is at least ten years old and I just used it to glue a grip back on my ZTR mower.
