Old 06-09-2010, 11:06 AM   #1
Armaan's Avatar
Trader Rating: 49 (100%+)
Default Which Turnigy LiPo for RC10B4 - RC10T4?
Turnigy 5200mAh 2S 30C Hard-Case Car Lipo Pack - http://hobbyking.com/hobbyking/store...dProduct=10277
Turnigy 5000mAh 2S2P 7.4v 40C hardcase pack - http://hobbyking.com/hobbyking/store...dProduct=11614
Turnigy 5000mAh 2S1P 7.4v 30C hardcase pack - http://hobbyking.com/hobbyking/store...dProduct=11613
Armaan is offline   Reply With Quote
Old 06-09-2010, 02:06 PM   #2
Zerodefect's Avatar
I'd go with the last one. The b4 and t4 don't need a high C rating.
My 5000mah Zippy's were a tight fit in my b4. Too tall and the carbon strap is hard to fit in. I don't change the batery in my b4 becuase it's a pain, I just levae it in and charge it.
I would actually recommend the smaller 4000mah Turnigy.
Like this:
http://www.hobbycity.com/hobbyking/s...dProduct=11598
or this Zippy, these are what I'm running and they work great:
http://www.hobbycity.com/hobbyking/s...idProduct=9435
Zerodefect is offline   Reply With Quote
Old 06-09-2010, 02:14 PM   #3
brickshouse's Avatar
You wont be able to run these batteries all the way to the front, youll have to notch the foams to run them periodcause the terminals come out the front of battery. They make some that come out the top, just got some for a frriend of mine. If your running stock your gonna want a high c rating, mod its not as important.
brickshouse is offline   Reply With Quote
Old 06-09-2010, 02:32 PM   #4
Zerodefect's Avatar
You can just dremel off the bit of chassis that interferes with the wires. I dremeled down my battery box walls to give my buggy more grip via a flexy chassis anyways.
Old 06-09-2010, 02:51 PM   #5
Armaan's Avatar
Dude you are 100% right...I totally glossed over that fact! Thanks...just saved me $100 or so (I was going to order 4).
Thanks!
Old 06-09-2010, 03:19 PM   #6
mikeohara's Avatar
I recently bought a T4.1 Brushless RTR and I paired it up with a Venom 5000mAh battery with a 50c discharge rate. I figured there would be some problems with the Turnigy packs and how they fit in the chassis, that's why I went with the aforementioned (because the battery connections were on top).
Last edited by mikeohara; 06-09-2010 at 03:35 PM. Reason: Forgot to mention the connections were on top.
mikeohara is offline   Reply With Quote
Old 06-09-2010, 04:00 PM   #7
Armaan's Avatar
Nice! How you liking the Venom packs?
Old 06-09-2010, 04:16 PM   #8
Redneck13x's Avatar
If you dont mind cutting up the little foam block a little. Put the battery in backwards. That way the battery is far forward, and when the foam is cut for the wires, it will fit.
Just a thought.
Redneck13x is offline   Reply With Quote
Old 06-09-2010, 04:22 PM   #9
Armaan's Avatar
Just a thought.
Excellent logic...that's true. Ah, now if they can just get them in stock!
Old 06-09-2010, 04:23 PM   #10
mikeohara's Avatar
The Venom packs for me provide more than enough power to send my T4.1 speeding off in any given direction. Since I'll be eventually racing in the Stock class at my LHS, I figured that a good battery like that would be great for what I'm wanting to do. I eventually want to run Modified, but I'll have to get the parts for everything very slowly.
Old 06-09-2010, 04:29 PM   #11
Redneck13x's Avatar
Im waiting on them too!
Old 06-09-2010, 07:09 PM   #12
you can cut the foam and put them in the front or back...if you leave 1 piece of foam in front of the cut 1, or, on ebay, they got the 5000 20-30c ones I told u about that have the wires coming out of the top. The ones at hobbyking have been on backorder for over a month, no tellin when theyll gettem in. Cost a littlemore though.....
Old 06-09-2010, 07:44 PM   #13
pdiddy777's Avatar
Default best ones to use in modified
which lipos have u guys used in modified trucks that worked the best ..in a 2cell ? 4000 5000 5200 ?and what rate? 20 30 thanx
pdiddy777 is offline   Reply With Quote
Old 06-09-2010, 08:06 PM   #14
Redneck13x's Avatar
Right now im using this one in my mod t4
http://hobbycity.com/hobbyking/store...idProduct=8357
Old 06-09-2010, 08:26 PM   #15
pdiddy777's Avatar
Default ok
how long does it last and what size esc motor combo u using ? thanx
