Caster Racing S10B Pro version 4WD Buggy
#422
#423
guys...have you try HW 120A with 8.5T motor, the car is a rocket, and all the option parts are available,,,check up the web site for all the cermeric balls, pressure diff, metal gears....etc.....
#427
Well after a battle with my lazy-azz postal lady, i finally got my car yesterday! shake down testing will begin tomorrow at Gulf Coast Raceway in houston. i havent seen any setup sheets yet so after i get some packs through it i will post a setup for covered clay. over time i will design and machine various parts to make the car better as well as offer tuning advice. one of the first things i noticed was the odd sized (odd to me anyway) wheel hexes so i machined some delrin Hexes for the front that allow you to run Durango and Losi wheels, they have a step in the back that also keep the hex from rubbing the bearing. now im going to source some .062 or 2mm roll pins so they dont fall out on the ground when you are changing tires and also because the Losi style wheel needs shorter pins. at any rate enjoy the pix and Happy new year to all. oh and i have a fix for the "stripped" delrin gears, will post up in a few days.
#428
Also I keep hearing about the carbon fibre but I can't seem to find who or how much this sells for? I like the idea of having a stick pack so I can swap batts from SCT to 4wd buggy...
#429
The info can be found here. Looks SWEET
http://casterracingusa.com/product.p...&cat=61&page=1
#430
http://www.diggitydesigns.com/D3_Off...ster_S10B.html
as for dirt getting into the chassis area, I have yet to have an issue, but I run at hardpacked dirt/clay tracks. Even with my sct, I only get a little dust inside.
#432
I finally pulled the plug and purchased a slower motor to run at the track. I'll have video sometime this weekend
#433
Suspended
I was going to get some the other week, but I had the parameters set wrong on my esc. I thought I slowed it down with the punch control but instead increased it, making the car well overpowered for the track I was at. In which, caused the car to turn super slow lap times as it was way too much to drive.
thank you sir.. You could have just turned down the EPA on your Radio thus only using a percentage of the power of the motor... I do this with most buggies when the track is a little loose, or smaller than normal.
Thanks again Gene
#434
i will have some video saturday
#435
I will be running the Sniper at the CRCRC midwest race you can watch it live i believe .Im the only Caster entry
