Traxxas Rustler
Traxxas Rustler
hello everyone, im new to the site but not to rc cars. lately my car , the traxxas rustler has just been destroying speed controls. i need help i has killed 2 in one day and i've gone threw 4 total. i need help getting my gearing right. thanks for your help
Edit: i am running a 29 pinon, 86 spur, speed gems nitronite motor, off road, race and i wasn't using a xl5 but i have one in now and a 7.2 v
I suggest you post your current setup: motor/esc and gearing so that you can get the help your asking for.
Also are you a racer/ basher? on road/ off road? if you explain the situation it will make it far easier to offer a solution.
just my opinion of course and only trying to help.
Is your ESC still mounted high on the shock tower. I remember some new racers at the track killing their ESC by landing upside down and wacking the wires and top of the Esc. Throwing alot of shock into the board and poof.
Also check the wire connections. Move the ESc down onto the chassis if it fits. You may need to solder new wires to pull that off. I love the XL5 esc.
I would have to say its the motor and the gearing. the xl5 can handle down to a 12 turn motor that is a 550 size (titan) and down to a 15 turn motor that is 540 size. the speed gems nitronite motor is a 12 turn 540 size. and a 29 tooth pinion with a 86 tooth spur is way to high.
R/C Tech Elite Member
According to your post your running a speed gems nitronite:
And your running a Traxxas XL5 ESC:
This seems to be a problem because your running a brushless motor on a brushed ESC...
double check what your running dude, also the XL5 and most ESC's have a motor limit, if you exceed the motor limit your ESC goes poof which is more than likely your problem
Ok so first my motor is a brushed and its silver. Second I am going to the hobby store tommorow and I'm going to get a new motor a new spur and a new pinen for my car any suggestiong on what I should get. I want my car to be fast and controlable that can go from speed runs the the track..... and I want to keep it like under 150
If its a brushed motor you want than a 15T would work fine, any lower and it will most likely over heat easily. For gearing an 86 tooth spur gear and a 13 tooth pinion work well for me with a 15T motor and the stock XL5 ESC.
