Old 05-31-2010, 04:39 PM   #1
Questions?? 1/8 scale diff help
i just started racing 1/8 scale truggys for the first time, i am running a rc8te with a tekin rx8 and t8 2000kv combo with a 4 cell lipo 35c but i cant seam to keep the front end down under acceleration. i am running the speedo on its mildest settings and every one at the track keeps telling me it is my diff oils(but are all different ideas on what to do). i have always raced 1/10 scale so this is completely foriegn to me any suggestions are info on what changing the diff oils will do.
RC8Te tekin rx8 t8 2000kv, spektrum dx3s
sc10
jammin crt .5 lrp spec2 .12
krazi kid is offline   Reply With Quote
Old 05-31-2010, 04:50 PM   #2
Zerodefect's Avatar
Diffs won't help, your trcks putting the power down well if it's trying to wheelie. Reducing your center diff fluid will send more power to the front and allow the front to diff out.
Are your front tires ballooning but your rears aren't? Then use thicker center diff fluid.
reduce front droop
move battery forward
soften front suspension (maybe getting bounced up into the air)
stiffen rear suspension
add antisquat
use less trigger, be smoother
increase rear wheelbase
Zerodefect is offline   Reply With Quote
Old 05-31-2010, 05:54 PM   #3
if you use thinner diff oil the front tires will probably balloon a lot. you could put thicker oil in it and make it so it takes off really hard so the the rear tires slip and dont get any traction then it wont wheelie and it will be a nice controlled take off.
mopar1994 is offline   Reply With Quote
Team Associated 1/8 scale Truggy Info and Tips Kevin Boyle Nitro Off-Road 4505 11-14-2017 12:51 AM
Team Associated 1/8 scale Buggy Info and Tips Kevin Boyle Nitro Off-Road 11189 03-12-2013 06:52 PM
1/8 scale off-road Electrics adrictan Singapore R/C Racers 6612 06-12-2012 06:02 PM
Official: Novak's 1/8 Scale Nitro to Electric Conversion Kits NovakTwo Electric Off-Road 1144 01-04-2010 04:49 AM
