1/10 4wd buggy + front spool? (xxx4-g+)
Hey guys,
Anyone run a front spool in a 4wd buggy? Seems like not many people are running front one ways (indoor xxx4) and was wondering why I havent heard of spools? On paper sounds like a win win, brakes and killer acceleration.
Im running a losi xxx4-g+ and love the way the one way feels but hate I have no brakes, im just curious if there will be a drastic loss in steering and poor tire wear or will things feel close to the front one way but with brakes? Guess losi makes a front pulley to convert to a spool (A3325) and I think i might try it.
I would think it would cut down on you initial turn in quite a bit.
im guessing with a front spool in a 4wd off road that the turn in may be inadequate, just a guess anyway. Where as in onroad, there is heaps of traction for the front end.
Suppose if you want a front spool but cannot get one, just tighten up your front diff as tight as possible, then it will be like a spool. I have heard people put traxxas slipper pegs instead of balls in their ball diff to lock up front diffs to act like spools in onroad, maybe give that a try?
I run the ball diffs at both ends and judt run the front one a bit tighter than the back. You can also use the one tooth smaller pulley to over drive the front if you want more authority with the steering. I tried it and it does work, but I was more consistent with the equal front and rear drive ratios. If you like the feel with the one ways though, I think you will like a tight front diff with the over drive pulley up front. It actually forces the car to keep the tail in more in tight corners, for a less tail out attitude, even while coasting or braking, not just under power like the one ways do it. I am by no means a great driver. My reaction time is not up to what that car can do, so i have tamed mine to make it nicer for me to drive more consistent, if not the fastest. Now that I have learned a bit more about the setup of the car, I may have to give the front overdrive another go and see how it feels with the softer front shocks I am running now. When I had the heavier oil in the front I just didn't have enough front traction to make the overdrive front work well, it had more push on tight turns. I tried front one ways in the past on a Kyosho Optima Mid and it did work on very tight track when the rear only braking let me turn it on a dime, but I was also much younger then and had better reactions, and no where near the power of today's brushless beasts.
Sorry, not to hijack this thread....but my son has a XXX-4 front one-way spool. It is brand new ( from the UK) but not in the package. It is for sale only because he can not use it in his XX-4.
$60.00US shipped.
Email [email protected] for pics
$60.00US shipped.
Losi slipper spool
Why not use the xxx-s spool pads Basicly just small rings of wet n dry sand paper remove the diff balls and put the sandpaper rings in place (rough side towards pulley) an build diff as per normal
gives a spool effect but in a high stress situation it will giv a little so as not to break something on the car
much cheaper than buying a proper spool and much easier than modifiying for traxxas pegs
and u can swap back to a normal diff if your not happy with it and won't hav cost a fortune
Hello !
I am also a new member. Would a newcomer be warmly welcome here? Good day you guy !
