Old 05-08-2004, 03:10 PM   #1
tr6_guy's Avatar
Default More power means tighten the slipper clutch
So, I went out today and bought a Chameleon 2 19T motor for my Losi XXX-T. Now, whenever I try to accelerate, the spur gear slips. I assume this is because the Chameleon 2 motor has a lot more torque than the old 19T motor that came with my RTR truck. This is normal, right? All I should need to do is tighten the slipper a bit and I'm good to go.
Any tips on how to properly tighten the slipper?
tr6_guy is offline   Reply With Quote
Old 05-08-2004, 07:06 PM   #2
Aaron Waldron's Avatar
Are you sure it's the slipper and not the diff?
Take the gear cover off, and hold the right rear tire and the spur gear with your right hand. Now try to turn the left tire. If the slipper spring and nut is turning, then it is the slipper. If they are not, it's the diff.
Tighten the slipper nut until the left tire is considerably difficult to turn using the same test. If it is the diff that is slipping, place an allen wrench through the slots in the outdrive when lined up with the slot in the diff screw, and turn the opposite tire clockwise (in very small increments). The slipper spring and nut should always turn when using the above-mentioned test.
Aaron Waldron - LiveRC
Aaron Waldron is offline   Reply With Quote
Old 05-09-2004, 03:53 PM   #3
Tech Legend
Cain's Avatar
Trader Rating: 205 (100%+)
Aaron's right.
Also, did you hear a cherping sound ? if you did thats the diff slipping.
Rustler Slipper Clutch Gregg Rookie Zone 5 06-10-2008 04:37 AM
WTB rs4 slipper clutch assy lewlew R/C Items: Wanted to Buy 0 05-21-2008 10:38 AM
slipper clutch new2this Electric Off-Road 3 05-30-2007 05:00 PM
New AE GT2 RS Slipper Clutch? Mjk87 Rookie Zone 2 03-07-2007 02:46 PM
Slipper Clutch Question. SmokinPhred Rookie Zone 1 06-03-2006 08:56 PM
SEO by vBSEO 3.5.0
