xxx4-g rim questions >
Old 05-14-2010, 07:01 PM
Default xxx4-g rim questions
ok i just bought a xxx4 i need rims and tires for my local track. i was on amain hobbies cant seem to find the rims for it. will the b44 rims work?
lmarinukjr is offline
Old 05-14-2010, 08:08 PM
badassrevo's Avatar
yes, but here are the Losi wheels.
Yellow fronts
http://www.amainhobbies.com/product_...heels-Yellow-2
Yellow rears
White fronts
http://www.amainhobbies.com/product_...Wheels-White-2
White rears
badassrevo is offline
Old 05-14-2010, 08:19 PM
The wheels sort of fit, but the offsets are wrong and there are some clearance issues, get the right wheels.
GSMnow is offline
Old 05-15-2010, 12:18 PM
Suspended
Swap out the stock front hex's for some B44 ones. Then you can run the Losi, Associated, or JConcepts wheels. The hex's on the B44 rims are deeper than the Losi ones so you need a thicker hex.
ifuonlyknew is offline
Old 05-17-2010, 11:10 AM
RC Dad's Avatar
Trader Rating: 26 (100%+)
2wd losi front rims have the right hex and offset but you'll need to drill out the center hole slightly to make them fit on the 4wd
RC Dad is offline
Old 05-17-2010, 12:32 PM
Briguy's Avatar
Trader Rating: 125 (100%+)
Do not do this !!
These rims are made for 2wd and not to be power driven , which will strip out the hex mold in the wheel . There is a reason the hex on front 4wd wheels have extra material as the fronts are powering not just rotating like 2wd .
Use XX4 / XXX-4 wheels .
Briguy is offline
