Losi xxx-cr vs associated b4
Been looking at both kits and determing the more solid buy. Was set and bound on the losi but now that look im not seeing much difference other then a few one being the gear ratio for the losi is 2.43 and the associated being 2.6 Parts on the associated is cheaper and parts on the losi offcourse is higher some times the price tag can tell alot then again sometimes I fill a person falls into the hype of a certain paticular brand. Could anyone give some solid facts on either buggy that could help? Thanks.
I've had both and I feel more consistent with the Losi. The B4 was fast, but the handling was right on the bleeding edge it seemed (it felt "twitchy"). One time it would be OK in a corner then the next time through, with no perceptible change in the way I was driving, it would hook. The Losi has been far more stable and consistent for me.
Both are very capable race cars. At our track the B4s are a bit faster, but not by much... Between the two, the real difference willl be the driver. Choose the one you prefer and then work on learning to drive and set it! You'll be just as fast as other drivers with the other brand...
Get an RC10 and learn to drive it! It has the best corner speed of all buggies, the best differential and soon to have the best shocks Most importantly looks the best Just make sure your wrenching the night before a race is over before midnight, because it does require a good nights rest to wheel it properly
R/C Tech Elite Member
B4
I have a B4, I would recommend it to anyone wanting a 2wd 10 scale. Very quick and consistent and with the right setup and driver very easy to drive. Parts avaliablity is going to be better on the B4 than the losi by a long shot. Just my 2 cents!
They are both great cars for sure. They are well designed, handle great, and are for the most part pretty durable. But, the main thing is parts availability. Just about every LHS has parts for either or both. I bring this up because there are other buggies out there that are just as good, like the Kyosho RB-5. The RB-5 is an awesome car, in fact its handling characteristics are often described as being right in between the XXX-CR and the B4. But, getting parts is a little bit more difficult.
I have driven both the Losi and the AE. The Losi has more natural under-steer than the AE. But, both cars can be set up to accommodate many driving styles, which is probably another reason why they are both so popular. If you can, try them both. Just remember, you are going to have a blast either way you go.
I agree, driving with a push is generally better. I actually have my B4 set up to drive with more under-steer for that very reason.
I spent time running both this year. Want to buy my Factory Team B4?
How much diffrence is the factory b4 vs the other b4 cause ive noticed a few responces saying get the factory out of the two.
stering servo any recomandations for either one as far as losi does better with this one and the associate does better with that one?
Factory car has titanuim turnbuckles, all grapite plastics (except the chassis), threaded shock collars, upgraded shock shafts, aluminum servo mounts (there are a TON of good servos, Futaba 9452 is particularly nice), lightened diff outdrives.
Am I missing anything?
The Losi car is Factory team level spec, they do not offer the car in a downgraded spec.
I had driven Losi for many years; then ran a B 4. Sold all my Losi stuff and have never looked back. B 4 is right on the edge and that is how a car is fast. The factory setup has worked at every track I have run it at. I would go with B 4.
I have now switched to the X Factory X-6 with the Associated Shocks and this is a great car. The motor in front of the tranny and four gear tranny make this car launch like a rocket and it turns better than XXX or B 4; but with motor in front of the tranny the rear end does not swing out.
