Old 05-02-2010, 06:41 PM   #1
Default Motor oil as shock oil
I bought some 30wtmotor oil at the store for 3 bucks for a quart, I used it as my shock oil and it works great plus it's alot cheaper!
Rustler vxl
forest_parker is offline   Reply With Quote
Old 05-02-2010, 06:43 PM   #2
YDBD's Avatar
Send a message via MSN to YDBD
it may eat your silicon o rings in the shocks as well as the plastic parts.....so you will need that whole quart to refill them every run....because leak they will...
Jon
RC and Beer Brewer
the only way to DUI!
YDBD is offline   Reply With Quote
Old 05-02-2010, 06:49 PM   #3
Hoops's Avatar
Why would it eat the plastic & o-rings?
R.I.P Zoey
Hoops is offline   Reply With Quote
Old 05-02-2010, 06:50 PM   #4
if its 10w30 its 10wt oil with the shear strength of 30wt. any oil that has a 10w before any other number is 10wt oil. 20w50 would be 20wt oil. etc. food for thought. and yet the petrolium based oil will eat the seals.
dragonracing is offline   Reply With Quote
Old 05-02-2010, 07:00 PM   #5
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Motor oil will work fine. It will eat some seals.
Silicone was chosen to replace motor oil in the mid-late 80's for it's anti foaming and low heat changing properties.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 05-02-2010, 07:02 PM   #6
YDBD's Avatar
motor oil has solvents in it to break down tars, waxes and other build up. In my experience most seals on a motor are cork, rubber, metal that come in to contact with petroleum based oil. Some seals/o rings may be a silicone base that has been formulated to resist breakdown from motor oil and gas/diesel...
Jon
RC and Beer Brewer
Old 05-02-2010, 07:23 PM   #7
Motor oil shouldn't attack the silicone o rings any worse than silicone shock oil does. If you go to a industry website and look up o ring materials and fluid compatability charts, the worst thing you can expose silicone o rings to is.......sillicone oil. That's why they swell in our shocks and should be changed out every week or two.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 05-02-2010, 07:27 PM   #8
So what's worse, motor oil or silicone?
Rustler vxl
Old 05-02-2010, 07:32 PM   #9
wingracer's Avatar
Trader Rating: 23 (100%+)
All oils thin out as the temp goes up. Silicone is the choice for serious racing because it changes less (though it still changes quite a bit). Silicone will give more consistent performance.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 05-02-2010, 07:40 PM   #10
LowClassCC's Avatar
Send a message via ICQ to LowClassCC Send a message via AIM to LowClassCC Send a message via MSN to LowClassCC Send a message via Yahoo to LowClassCC
forest.. for the $ you are saving go for it and just rebuild the shocks more often. it really boils down to weather the extra time is worth the savings.
but note even buying strait 30wt don't meant it will be the same thickness as associated 30wt or losi 30wt seeing that "wt" is a very generic and loose term.
LowClassCC.net
Over 3400 RC Documents Available For Download!
LowClassCC is offline   Reply With Quote
Old 05-02-2010, 07:47 PM   #11
rcman1993's Avatar
Trader Rating: 33 (100%+)
but the motor oil will be more consistent since it is for cars that cost lost of $$$$. it needs to be more accurate than rc oil. the only problem with motor oil is that it is darker. will look dirty if you dont know what to look for. i would only go with synthetic since the real oil would be inconsistent.
X-Factory X-6 Squared w/17.5 Duo 2, Tekin RS Pro, 3PK
AE, X-Factory, Tekin, Trinity, Futaba, Proline, JConcepts, Team Orion
AMS Raceway, Larrys RC
rcman1993 is offline   Reply With Quote
Old 05-02-2010, 07:47 PM   #12
Yea I brought it for a ride I didn't see no difference, I'm not a big racer, it's my only rc and I just bash and race on my backyard track, so for me it's good
Rustler vxl
Old 05-02-2010, 07:49 PM   #13
I got a quart I'll change the oil more often
Rustler vxl
Old 05-02-2010, 07:56 PM   #14
rcman1993's Avatar
true. you would have all this oil. now you got to buy the seals.
Old 05-02-2010, 08:00 PM   #15
I'll buy a couple next trip to the hobby shop, it can't be much worse then silicone
Rustler vxl
Tmaxx shock oil Transamman25 Monster Trucks 9 08-11-2009 09:37 PM
Unespected handling due to shock oil change - please explain Cole Trickle Electric On-Road 59 01-11-2004 01:00 PM
