Old 05-03-2010, 11:56 AM   #16
I've been running a Firebolt 15T in my Slash for a few weeks while I wait for a replacement Titan from Traxxas...
The Titan is definitely torquier and has more punch to me - We have a pretty technical track and I'll be switching back to the Titan asap.
The HPI does sounds kinda neat though..
Both titan motors I have failed at the bearings so I'd recommend keeping it clean and well lubed..
bside is offline   Reply With Quote
Old 05-03-2010, 12:28 PM   #17
Originally Posted by Neu_Racer View Post
Well I put the Firebolt 15T in and drove it around my kitchen. It seems kinda like a turd. I'm running a Reedy 5000mah so I don't think its the battery.
I would like to run the Titan but now I'm scared of burning up the brand new speedo.
I feel like such a noob. I haven't been in the hobby long enough to know a whole lot about brushed setups and haven't ran anything but brushless in over 18 months.
I don't think you'll burn up the speedo. Besides if you do they are always on sale for next to nothing. In fact I have a set of brand new blitz electronics I need to put up for sale. I'll be happy to get $30 for the whole lot (ESC, receiver, servo, transmitter)
chiro972 is offline   Reply With Quote
Old 05-03-2010, 02:27 PM   #18
Neu_Racer's Avatar
Trader Rating: 211 (100%+)
I had two blitzes I parted out and kept the electronics from one which is what I'm currently using. Just because they're cheap doesn't mean I want to burn up a new ESC!
I'll give you $30 for all the electronics you have. Is there a motor too? Send me your Paypal info.
Neu_Racer is offline   Reply With Quote
Old 05-03-2010, 02:32 PM   #19
cyclone x's Avatar
"better luck" as in not blowing up or as in being faster and winning more races?
It also weighs less so maybe I will go with that one. I don't need gobs of torque. its a really small track.
winning alot more races and staying like brand new
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 05-03-2010, 04:32 PM   #20
jk racing's Avatar
Trader Rating: 20 (100%+)
I have raced both in my Blitz. I am currently using the HPI motor (I have a couple of them) and have no issues with speed. I do feel a well maintained Titan is a better choice, and once these 2 HPI motors wear out, I will be going back to the Titan. Personal preference I would guess. I tend to gear the HPI motor about a tooth higher than the Titan, cant explain why, but that is where I have had the best luck.
--Joey --Venom Batteries & Chargers -- Maclan Motors
Old School Racer & Vintage RC Car nut
RC10CE (X3),B2,B3,B4,B5, B5m, B6D - 10T,T2,T3,T4,T5M
JRX2-LXT-22.4 1.0
RC10M (custom), RC10L4-O (Velo custom), Academy SPX Pro-O (Velo custom)
jk racing is offline   Reply With Quote
Old 05-03-2010, 04:53 PM   #21
cyclone x's Avatar
because the lower the turn number the faster they are
Chase Chandler
Old 05-03-2010, 04:57 PM   #22
jk racing's Avatar
Unloaded RPM, the HPI motor spins faster. NIP HPI tested against NIP Titan. The HPI motor also pulls more amps (2.1 average @ 5 volts for the Titan, over 4 for the HPI, tested back to back).
When loaded, the torque of the Titan shines, on these trucks (being heavier than "standard" 1/10 scale) torque helps. BUT, if you are running on a loose dusty slippery track, the lower torque of the HPI helps with traction.
JRX2-LXT-22.4 1.0
Old 05-03-2010, 09:45 PM   #23
RcRacing4Ever's Avatar
Ive ran both Titains & Firebolts... I break them both in a cup of water & dynoed them... In which they will spin an extra 2 to 3000 rpms after this break in.
I will say the Titain is torquer & lasts longer than the Firebolt...BUT the Firebolt will beat the Titain down the straight everytime...
just my 2 cents
- Associated Sc10 -
- FT TC5R -
Sponsors *My Wife & My Wallet*
RcRacing4Ever is offline   Reply With Quote
Old 05-04-2010, 03:51 AM   #24
cyclone x's Avatar
tita in a 550 can and HPI is a 540 can
Chase Chandler
Old 05-04-2010, 05:44 AM   #25
Can the Firebolts fit directly into Traxxas Slash in size? without change anything?
xmax is offline   Reply With Quote
Old 05-04-2010, 06:06 AM   #26
gapjr's Avatar
Trader Rating: 64 (100%+)
Yes it will.
gapjr is offline   Reply With Quote
Old 05-04-2010, 06:25 AM   #27
Its all in the gearing! I can make any of those motors shine. I gear the Titans to self destruct (in a slash 23/83), I have found that b/c of the crappy tolerance in these motors you will find one that likes the heat. I ran the 2nd GCS event with this gearing/motor in my slash and it took a 10min main to get in past 140 in degrees. But then I had another titan on similar conditions burn up pretty bad after 5 mins. So honestly each motor is diff.
The titan seem to handle the low roll out ratio b/c of there size and fan. But it does not mean I cant get simialr results with another motor. The Hpi you must gear differently. same with the reedy radon, which seems to be the fastest (most RPM). I have to gear down to 19/83 with a radon motor but yet I am faster than the Titan on the starights, but If I were to go up a tooth or 2 on the Radon, it would puff in minutes (smaller motor/ no fan)
If you want to be the baddest Mo FO in the spec class either A. buy alot of motors and find the golden ticket. or B. Go buy a Red Dot Slash Motor
!!!!!!!!!!!!!!!!!!!!!!!!!!!SHON HARDING!!!!!!!!!!!!!!!!!!!!!!!!!!
!!!!!!!!!!!!!!!!!!!!!!SWEEP TEAM DRIVER!!!!!!!!!!!!!!!!!!!!!!!!
!!!!!!!!!!!VIPER R/C SOLUTIONS TEAM DRIVER!!!!!!!!!!!!
!!!!! OFFICIAL TEAM TURTLE TRAX TEAM DRIVER!!!!!!!
!!!!!!!!NEXT LEVEL ADDICTIONS CUSTOM PAINT!!!!!!!
synap2012 is offline   Reply With Quote
Old 05-04-2010, 06:23 PM   #28
Neu_Racer's Avatar
Well i ran the Firebolt in the Slash today with a Reedy 5000mah 20C lipo and w/o breaking it in at all it took about 1/2 the pack before it was not embarassing. Then it was just a turd. Man I hate brushed stuff! I'm not even going to waste time trying the Titan. If forgot how crappy non brushless is!!!
Castle here I come!!!
