Mamba Monster
The problem with this is that the 3300mAh cells will drain first and their voltage will drop below 3.0v while the 3600mAh cells have more power left and hence a higher voltage. The MMM sees the overall voltage, therefore the lvc won't cut off until the 3600 cells have drained more, possibly allowing the 3300 cells to over-discharge and be damaged.
