xxx-nt rear toe
I have an xxx-nt and was wondering does anyone make a 0 or 1 degree rear block to change the toe in on the rear. any help would be greatly appreaciated
Trinity and Losi make different rear hubs that allow you to change the toe-in.
The pivot block includes three degrees of toe-in; unless you're going to be driving on the street only, this is really the minimum amount of toe-in you can run on the truck and still have it driveable in the dirt. Are you looking to add toe-in or take it away? |
i want to run dirt oval so i wanted to change the rear toe. its at 3 degrees now but i want it at 0 or 1 degree
To tell ya the truth, I really don't think that's the best way to go with the truck..toe-in usually yields more rear traction.
In any case, Trinity and Losi both make 2 degree rear hubs that, if put on backwards from normal, would give you 1 degree of toe-in per side. That's the least amount of toe-in you can get without hand-making parts. |
thanks alot:D
