Old 03-27-2010, 12:52 PM   #1
Default Dynamite Fuze SC ESC/brushless problems
I was hoping that someone might have a suggestion for a problem I'm having with a new brushless setup for my son's Blitz.
I just installed a Dynamite Fuze short course brushless ESC / 3300 KV motor combo and I'm having problems with it "cogging" (at least I think that's what it is). I've gone through the setup per instructions and that all seems fine, it's just that when I punch the throttle off the line, it jerks and even seems to go in reverse for a split second. If I apply throttle gradually and get it rolling I can go full throttle without a problem. It's also running very hot just in the few minutes I'm running it down the street.
I'm using a Turnigy 2C Lipo that I have run in my SC10 and it works great, so I know it's not a battery issue. The radio is an Airtronics MX3 synthesized. I'm geared at 88 / 23.
Any help would be much appreciated.
jnlisa is offline   Reply With Quote
Old 03-27-2010, 02:00 PM   #2
koopesv's Avatar
Trader Rating: 18 (95%+)
i would gear down to a 21t pinoin or adjust the timing and on the program card my friends timing was all the way up when he got his
Durango - Speed Passion - Trinity
Gforce Hobbies Raceway
Urban Heat Racing
koopesv is offline   Reply With Quote
Old 03-27-2010, 03:45 PM   #3
I went down to a 18T pinion just to see if it made any difference and it's still doing the same thing. I also adjusted the start-up power to the maximum- I heard that could help, but no dice.
On the timing- would I advance or retard it?
Old 03-27-2010, 04:07 PM   #4
Jstall7543's Avatar
Two words: Dynamite Fuze
need I say more?
RC is a way of life and a ridiculous hobby.
Ridiculously Fun! Subscribe to my YouTube Channel! Or ELSE! Hehee! http://www.youtube.com/user/Jstall7543
Jstall7543 is offline   Reply With Quote
Old 03-27-2010, 04:37 PM   #5
gangstafish's Avatar
Go To Horizon Hobby.com
gangstafish is offline   Reply With Quote
Old 03-28-2010, 08:25 PM   #6
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
To actually ANSWER your question, see the two posts above mine you will understand my intro.
You must retard, or turn down, the timing. More timing reduces initial torque in order to gain top end. However, too much timing can cause problems you are describing. Also, the Fuze system is sensor less, and as a result, may hesitate slightly when accelerating from a dead stop. Also, contact Horizon Hobby as far as gearing recommendations. Hope this helps.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 03-29-2010, 08:02 AM   #7
tedstryker's Avatar
Trader Rating: 69 (100%+)
need I say more?
YOUR CLUELESS TAKE A WALK...
A.E.RC8B3E
TLR 22T 2.0
Kyosho RT5
YOKOMO B-MAX4 III
YOKOMO YZ2 DT
tedstryker is offline   Reply With Quote
Old 03-29-2010, 10:18 AM   #8
turbomeyers's Avatar
I had this issue as well in my fuze . but it only happens after the motor is warm . so i geared it don as much as i could . this helped but not enugh to i installed a heat sink on the motor and now i have no issued with it , but turn down initial power and reduce timing . this setup has been working great for me and it is close to stock power of the titan .
Chris Meyers
Clutch Nutz R.C. Club Of Red Deer AB. Canada
Prop Busters R.C. Club Of red Deer
turbomeyers is offline   Reply With Quote
Old 04-22-2011, 10:53 PM   #9
Sorry hadnt had a problem with mine 125all day esc at 100
Empire37 is offline   Reply With Quote
