SC Truck for track rentals
I'm considering having rentals cars at my track to get people involved in the hobby and maybe to make a little bit of money later on. I would like a truck that has a low voltage cutoff esc or I can buy one seperate, buying $30 lipos is alot more feasible than buying $50 nimh's for obvious reasons. Traction is not really an issue as my track is as hard as and has as much traction as concrete. Last requirement is that is must be durable since it is a rental truck and I expect people to crash it into the pipe left and right.
I've been considering the Blitz mostly, I would buy a Slash but you cannot use a low voltage cutoff. The SC10 has a LVC but I think it may be to fragile, same with the Strke.
Any help is appreciated.
http://www.palmdesertrcraceway.com/
Video on home page
Video on home page
Use turnigy 4500 life packs.($30 packs)
slash w/ alum. shock caps
Then the big E-maxx brushed motors. (they will make the same power but run cooler & last longer).
With the 2S LiFe and 21t E-Maxx motor, wouldn't it be alot slower than stock. I would like it to be about the same speed as the stock slash. I think I will try that instead. How would the Blitz compare to the Slash for my application?
That's what I was originally thinking. The track is located right by a major hiking trail where there is about 100 cars right by the track on the weekends and I get probably 5 people a day asking if I have rental cars, so I think it might just work out/
I just got a 21 turn in my slash with 23t pinion and 86 spur.Its seems a little faster on top end and still quick acceleration,motor does get hot even running in grass like the 12t titan did with 19 t pinion and 86 spur.I'm still running 7 cell 8.4 traxxas battery,but have a 9.6 8 cell 5000mah on the way.
My track calls it "Rent a Wreck." You can rent a RTR Slash and get a race entry for $30. A Slash really seems ideal because of how durable they are. Even a Blitz won't hold up as well.
Maybe check craigslist to get an ESC with lipo cutoff. I sold my Kyosho ESC w/ the motor for $20.
It's looking like the 2.4ghz Slash's and the 4500 LiFe's right now.
The rent and race is a good idea, might have to try that out once club racing starts.
