SLASH 4X4 TOP SHOCK collar bushing?
I saw a guy at the track that had put a nut and bolt through the top shock mount,he had a plastic bushing the same diameter as the stock collared bolt,my stock bolts loosen up all the time,I want this set up,the guy left before I could check out what he had done,antone know where to get these?,thanks in advance
You could try locktite if your bolt keeps loosening up... Use blue lockite, because red would be too strong...
But, they put blue locktite in red bottles, so read the label before you buy, lol, its messed up!!!
They come free with your truck.
They are attached to the shock parts tree with your spring spacers.
It is a good mod,use a nylock nut with the bolt and your shocks will never come loose again.
