WHAT WOULD YOUR SC SPEC CLASS BE
ok your in charge of setting the short course spec rules what kind of speedo, motor, tires would you legalize and why
here is mine
Speedo Novak Havok spec
Motor Novak Havok 17.5
Tires J concepts goose bumps
Battery Hobby King Turnigy 5000 mah 2s 20c
now box stocks would still be allowed. I picked the havok speedo and motor for dependability and price. The goosebumps cause everyone says they work everywhere. and the turnigy pack because of the $19.99 price tag
here is mine
2wd? Its a good starting point. This topic will be discussed forever. When the slash came out and evrybody ran it stock it was a great class and very affordable. Then came the snowball and now we are driving cars that are way faster than an actual full size s/c truck and money is a big factor.
Just like we did 2 years ago... change out the radio and shock oil... and that's about it. If you want to run brushless, great... there is a stock class and a mod class.
We still run box stock at my track. I'd like to see some kind of brushless rule adopted just for the ease of maintenance
I have to agree with this. I think "marrying" a certain kit or electronics is a bad idea. The 13.5 motor and tire size are easy to tech. You need to let the free market work to insure the best quality/cost ratio.
I have been running the ROAR Stock rules for nearly a year. I have worked a Slash and a SC10 to get the most out of the class and the 13.5 is so much better. More motor and you have to call it Mod or Open.
kit motor or 17.5 brushless
all trucks can use other kits stock tires
no other "mods"
no other "mods"
Intermediate Corr
Any short course tires wheel, chassis, 17.5 brushless motors
Stock Corr
Any SC, may be able to mix speed controls and motors from other manuafactuer. Stock Tires only. Any Battery.
__________________________________________________ ______
My rules
Spec Slash Class
Spec Blitz Class
Spec Kyosho Class
Spec SC10 Class
4 Seperate catagories would be better. Throwing them all together is causing the problem. cEither that or run them all together and limit the battery. Any battery is just BS. Any speed control and motor from other maufacterer is also BS, because the fast guys have already figured out
the fastest combination. One of the fast guys runs Kyosho Esc, with a Kyosho motor, kyosho servo in a hpi bLITZ.
And Intermediate Class is fine as is.
There should be 2 classes. Fast drivers & slow drivers.
