Best Step Pin Tires???
Hey guys!
I often run on a very loose, loamy black dirt offroad track and the only tires that really work well are of the Step Pin style. (no BowTie, Mini Pin, or Fuzzys on this track) All I have ever ran on my T4 and GT is the Stadium Truck ProLine Step Pins in the past but the Losi and Trinity (TRC) both look nice too. So my question is what is your favorite Step Pin tire Mfg? (Proline, Losi, Trinity, etc.) What is your favorite compound? (M2, M3, Red, Silver, etc.) What is the best front tires for a soft loamy track? It's about time to buy another set of tires so any comments or suggestions are appreciated. Thanks!! :D |
Losi Red Step Pins are my choice for loamy tracks. They last quite a bit longer than the Pro-Line step pins, and the larger pins will help dig through loose dirt.
Losi Red Directionals are also my favorite for front tires. Make sure you run the straight ribs on the inside of the tire for the most consistent performance. |
Re: Best Step Pin Tires???
Originally posted by SS LS1 Hey guys! I often run on a very loose, loamy black dirt offroad track and the only tires that really work well are of the Step Pin style. (no BowTie, Mini Pin, or Fuzzys on this track) All I have ever ran on my T4 and GT is the Stadium Truck ProLine Step Pins in the past but the Losi and Trinity (TRC) both look nice too. So my question is what is your favorite Step Pin tire Mfg? (Proline, Losi, Trinity, etc.) What is your favorite compound? (M2, M3, Red, Silver, etc.) What is the best front tires for a soft loamy track? It's about time to buy another set of tires so any comments or suggestions are appreciated. Thanks!! :D I recomend trying both of Panther Racing Tires "Step-Pin (Part #T-300) in Med-Soft compound, and there "Stud" (Part #T-340) in Med-Soft compound as well. For the front of your truck, use the "V-Rib" in Med, or Med-Soft if you want less steering. I recomend getting a set of each so you can test at your leaisure which one you like best. I run at this track weekley and it is the only tire that "Wins" races there... Hope this helps you out, and gives you that fourth option. ;) GB :) |
Panter steps kick butt. I won several long mains with them. I also like the losi studs they work well. Proline lugnut t are also very nice and they last almost as long as the panthers
buy all of them and see what u like best
youll never now whats better till you actually try it out other people might drive different which will make them like a specific tire better than other 1s |
Gabe, what local track are you referring to in your post. I am from Montclair so your track may be the same as mine. I did go out and buy Panther ribs for the front of my Mugen MST-1 in med-soft compound. Will these be Ok for loamy tracks such as revelation raceway?
SSls1- Try Lug Nuts or any Proline stud. See the thing is the Proline tires will fit the rim properly. I have ran Losi treads on my ASSO.. and raved. Never the less certain treads work better on certain trucks. And certain rims fit certain rubber better. If you haven' tried Ifmar Studs thats my Losi recomendation the hue would be red. For Proline its Lugs. Panthers are awesome- although I perfer to use grey bomb one in lue of their freebie foam.
Losi step pins for loamy track. Red or silver compound. Panthers are a good choice as well , but I still prefer the Losi's.
Originally posted by wild gopher Gabe, what local track are you referring to in your post. I am from Montclair so your track may be the same as mine. I did go out and buy Panther ribs for the front of my Mugen MST-1 in med-soft compound. Will these be Ok for loamy tracks such as revelation raceway? GB :) |
