Hobby King just restocked several backordered Lipos
#16
For 1/8 scalers - this may work out well. For $40, 4S, 4500mAh, hardcase.
http://www.hobbycity.com/hobbyking/s..._hardcase_pack
I only question whether I'll get enough runtime. I've already got one of the 35C 5000mAh Turnigy packs, which has been great.
#17
damn, OOS! And I can't find anything comparable anywhere. Someone PM me when they have some back.
#19
as long as your not trying for 20 min mains.....15 might be close pending traction/driver but 4500 i would think would be on par....weight wise they are a bit heavier then i would like to see...but you have to account for the case i guess.....5000 30C soft cases are 510-515g.
#20
i just got one of the hard cases and the cells are loose in the case, i will have to see about taking it apart and making sure they are tight
#21
I'm debating just pulling the trigger on the Hyperion G3 VX 5000 4S pack. With the 5C charge rate I could probably get by with just one, plus my Turnigy as a spare. It just sucks that I could have 3 of these 4500's for the price of one Hyperion.
#22
Yeah, last year was something like 15 minutes with two mandatory "fuel" pit stops. Not sure what this year will bring with more people running electric 1/8 stuff...Either way, seems like a 4500 might be pushing it especially if I don't want to do a real deep discharge.
#23
I just got an email alert from HK saying the Turnigy 5200mah 2S Hardcase batteries were back in stock. I checked it out and found that they were priced at just over $22 each I ordered 8. I couldn't have bought 3 comparable Lipos from my LHS.
All I can say is WOW! I also saw that there were several other batteries that have been backordered that were back in stock as well.
Here's the ones that I bought:
http://www.hobbyking.com/hobbyking/s...dProduct=10277
#24
It'll still take quite a charger to charge those at max rate as well . . .
http://www.hobbyking.com/hobbyking/s..._30C_Lipo_Pack
#25
most guys i know run soft packs....guy's running dual stick packs are normally hard cases but i dont see the benefit to a Hardcase VS softcase....so ill run my softs and be happy.
#26
#28
why is everyone stuck on 500 mah, you guys know its only gonna make 1-2 mins of difference? chances are people that are running 4s setups arent going for long run times anyway
#30
i couldnt with a 5000, i just barely made 17 with a 4s 6000 babying it around the track
